Hi New to the forum, currently working on 4AGE build myself for my AE92 GT-S and found this thread. My build is for the street but I would like to get into amateur track racing just for fun.
My first build I'm looking at Tomei Cam gears, Tomei 264* cams, 4-2-1 header, thin head gasket .8mm?, simple pnp and valve job, and obviously timing kit replacement and short ram intake with stock exhaust size straight pipe with chambered muffler and resonator. Everything else stock.
Questions, I would like to see roughly a 40hp increase from this as it will cost me around $1300 to build. Can I see this kind of gain WITHOUT ITB's and stock ECU? I'm basing my info off of the dyno graph previously posted about the smallport with a similar build on page 4.
Has anyone seen an actual number of HP or KW gain from switching a ram intake to ITB'S running a 264 cam?
and finally, any tips on the best way to increase CR to 10.5-11:1? will a .8mm head gasket suffice or will I need to deck the block or change pistons?
