I want it all.
Hey guys,
You have probably seen the car for sale ad. This is also an EOI on the parts in the car.
Once again, EOI, nothing will be sold till i think its worth it. Pictures upon request/Soon
Parts:
1. 7AGE Engine Package. Motor + Gearbox + ECU
-Custom 7AGE Motor (7afe bottom end with big-port 4age head) (not even 2 years old)
-7AFE Bottom end - Honed, 0.5mm Oversize bores.
-Standard crank (mid-sized)
-Kings Main bearings
-Standard Conrods (Resized + new bolts)
-ACL Con-rod bearings
-Hypatech Small-port 4AGE Pistons 0.5mm Oversized. (new)
-Hastings Piston Rings
-New standard thickness 4AGE Toyota head gasket
-Standard Big-port 4AGE Head, with some mild porting.
-New Head-bolts
-4AC Flywheel with new bolts
-Apexi Air Intake
-TRD style extractors
-Compression ratio: 11.4:1
-Standard 4AGE ECU (been run up on dyno, safe as houses)
-JDM T50 gearbox (good nick! redline oil in it)
-Extreme Heavy duty clutch in good nick!
Notes:
-Great reliable motor, still has alot of the factory goodies, Coldstart etc.
-BOLT IN JOB!!!
-Took some heart when we built this, new seals throughout etc. not a throw together!
-Bottom end was put together by TOXIN off these forums, we went to great detail in the build. you can find it in this thread:
Pricing: $3,000.00
4. AE86 TRD 2WAY LSD & TRD 4.778 FINAL GEAR - Suit Kouki T Diff. 'SOLD/ON HOLD - dehney'
-TRD 2Way LSD Center
-TRD 4.778 Final drive
Notes:
-Selling as a bolt in job center, the best proven ratio with a 4age ae86.
-I bought this center used off yahoo japan about 2.5 years ago.
-Had it rebuilt/tightened by Duncan at TOP COG. (qld diff specialist)
-Comes with a REAL TRD 4.778 ring gear installed (was also installed/setup by Top Cog)
Pricing: $850.00
Thanks guys,
Pm Me. Rob on 0403 756 872
I'll take the castor rods if you decide to part it out.
shotgun copper radiator
dude, that shell is a ripper deal, kind of wish i didn't jut buy mine and bought that.... damn you. really sad to see this pulled apart but it seems the way with such a well built thing no one can scrape together coin for all of it. good luck with everything mate, would be good to see you on here once in a while, enjoyed your vids
few people keen on the shell. dw ill still be as active as i am now! new vids, new good times!
thread updateddzzzz
Sent you a message regarding the shell.
damn i want those caster rods would be interested in cambertops if you sell seperate
Keen on front and rear coil overs if you part.
smokes, things are going fast. added you to the list Luke!
