Cleaned complicated Southernways mesh centres with a toothbrush and cotton buds.
Washed car.
Fitted under carpet sound/heat insulation for summer.
Changed oil but left on old filter.
Spanner check.
Clipped back seat back in.
decided i should get my leaking clutch master changed today, getting over soggy carpets
Washed car.
Spanner check.
fitted yellow cibie fog lights, received clutch master from ajps today woot!
just changed clutch master, bit of a pain to do, had to take out my drivers seat so i could lay on the floor to reach the clutch pedal inside the car, one of the hardest bits was trying to get the clutch line off, service manual said to take it off first but the clutch line ends up being to twisted to take off. so i undid all the bolts and pulled the unit out and let off all the twisted tension on the line by dangling the clutch master near the firewall. when i fitted up the new unit i could not get the line's thread to fit the new clutch master, thought maybe i stripped the threads on the line but it ended up being a shitty tapping job on the new clutch master, luckily i used a bolt from the seat mounts and reamed it in there which cleaned up the threads enough to get the clutch line started. then had to get one of my neighbors who is a 75yr old man to pump my clutch so i could bleed it. all works, also fed through some new cabling for the cibies up front, i'll let a guy at work wire them up.
did a oil change and fitted a genuine toyota oil filter, heaps better size then the ryco that was on it when i bought the car.
time for a drive
aarrrrgggghhhhh clutch master is fine, now my hard line developed a massive crack just next to the slave cylinder. anyone in melbourne got one, need it asap please
got a rwc for my trueno. now to book vicroads appointment and new daily here i come!
*wish i had three hands to give that three thumbs up* book in at dandenong, easiest place to get through the pits
fuck dandenong!! worst place apart from burwood, because they have second inspectors checking random shit, and big bosses checking up on shit, you live in the west filip, hoppers is the go
LOL seymour vicroads ftw!
SuperFunHappySliders
SR's are ghey.
Briefly took a glimpse of mine, then went back inside. all in a days work
