Hey guys been on here for a while probably time to let you know what I've got
This is what it was when I got it
fully engineered
1984 ae71 map sensored small port gze
Haltech ecu t25 turbo 212mm flywheel with hd button clutch
Jdm t50 t18 diff Trd lsd
Jap struts rubbish springs dampers and sigma lca ps knuckles
When I first got it there where all sorts of fueling issues clutch was worn out motor was tired and gear box was rooted and turbo used to fall off all the time haha ( drove home from winton two hours turbo was held on with hose clamps and she still made boost)
First thing i did was coilpvers changed my life and made sliding therfofe braking t50s so much easier. Had another small port gze in the shed and a w57 in an old paddock bomb so the project began
New motor in with full reseal new extreme hd button clutch new low mount ss manifold turbosmart external wastegate and gt2871r turbo
Fuel system is in the process of being overhauled 22ltr foam filed bottom feed fuel cell
Vl turbo Pumb used as lifter to surge tank, then 044 feeds fuel rail tomei rising rate fuel reg,
There is more to write and I'll upload photos tonight when I'm on the computer
Looks pretty clean mate and a reasonable buy
I noticed this when it came up for sale last - good buy man!
I've put a fair few $ into it since I bought it. It was very sad but it was a good start as most the hard work was done
