bump 400 i don't need these anymore lowest ill go come and get em
have a pair of 264 deg hks cam shafts here come out of my 7a as im going bigger they have 8.1 and 8.35 mm lift are in great condition ill be crack testing them tmoz for piece of mind and ill give them a polish when they are at work with an acid bath so they will be as clean as a whistle
price is 600 for the pair
location is Sydney Sutherland shire
contact through pm
on a side note i can install them for you at an extra cost
the dyno pull to 300rwkw
faaark... tempted, how would they run in a stock bigport with stock ecu?
not well if you hit the limiter it will fry plugs a bit
bump up
Any cam timing spec sheets with these?
maby if you search google dude they are hks i bought these second hand but i dont have any
Sorry if these are dumb questions, new to 4AGEs. Would these suit an otherwise stock bigport with adjustable cam gears running stock ECU with a microtech piggyback?
Yeh mate they will. Same setup as what I'm running..
MOPAR or no car!
yeah mate will be fine can post em if you want
