Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 35
Thread: Velocity Stacks / Trumpets and Intake Adapter Plates
    Moderator Sam-Q's Avatar
    Endeavour Hills
    Default Velocity Stacks / Trumpets and Intake Adapter Plates
    Below are the main sizes of Velocity stacks kept on the shelf and their current prices for a set of four.
    Featuring:
    - Ideal transition: fine transition between inside of stacks to throttle for maximum flow.
    - Flange fitment: With a neat profile cut flange these don't have an backyard style slots but instead holes that are exactly 8mm.
    - Best induction: With a full bellmouth and parabolic intake shape these have an ideal induction shape.
    - Tube Shape: Tappered tube design for maximum pressure and highest flow.
    - Solid: 5mm thick flanges with stiff spun tubes.
    - Finish: Semi-polished for professional looks.
    To suit 20V Silvertop throttles:
    Length / Price
    20 mm / $150
    43 mm / $160
    70 mm / $190
    100 mm / $220
    110 mm / $220 (+$30 to machine to fit 20V engine)
    150 mm / $280
    To suit 20V Blacktop throttles:
    Length / Price
    20 mm / $150
    35 mm / $160
    50 mm / $170
    70 mm / $190
    100 mm / $220
    150 mm / $280
    Custom stacks:
    Need something not in this list such as for carbs? then enquire as a massive range of sizes can be made.
    GTiR Adapter plates:
    Ideal for boosted quad throttle engines or Aussie RHD owners who need an airbox. Price: $200 each with a gasket
    Intake plates:
    Will not suit RHD Corolla and Sprinters! Available for both Silver and Blacktop throttles and either ITG or Pipercross combined filters
    Endeavour Hills
    Pics:
    Pictures below thanks to Tyler:
    Dyno:
    Everything Below thanks to from
    Tim went from 120kw at the wheels with IMEC stacks to 128kw with T3 70mm stacks to end up with 137kw using some SQ Eng 110mm stacks!
    Dyno run:
    Moderator Frak's Avatar
    Jamie
    and my tuning
    Hachiroku since 1994
    Endeavour Hills
    ah yes how can I forget,
    my stacks, Tim's car and Jamie's amazing tuning ability
    Hair model Jacobxxx's Avatar
    Jacob
    Sunshine Coast
    What's clearance like on KE70 for the 110mm Stacks? Except my car has engine mounted 2" forward, ill probably have to get some tape measure out.
    Endeavour Hills
    normally 70mm stacks come very close to the brake booster, 110mm normally be for left hand drive only. However in your case it might fit.
    The combined filter adapter I am working on might fit as well.
    Timmy D
    North
    hey sam do you do stacks for DCOE 40 dellorto carbs?
    JJ
    Endeavour Hills
    I can if you give me the specs, haven't do so yet
    Veteran evil86's Avatar
    Phuoc
    Liverpool
    any performance gains between the lengths of the stacks or is it just for fitment
    Pick up Sydney
    Pics can be sent by phone
    Emails ignored
    Texts ignored
    Private numbers ignored
    Wankers abused
    Endeavour Hills
    definate performance gains, 110mm seems to be ideal for both a 4age and beams
  1. Replies: 28
    Last Post: 16th December 2012, 08:50 PM
  2. (QLD) 20V velocity stacks/Trumpets for sale
    By luke111 in forum Car Parts For Sale
    Last Post: 7th October 2012, 05:23 PM
  3. T3 trumpets/ velocity stacks silver with filters
    By ae8620v in forum Car Parts For Sale
    Last Post: 30th November 2010, 11:22 AM
  4. blacktop 20V velocity stacks / trumpets
    By dehney in forum Cars or Parts Wanted
    Last Post: 1st February 2009, 12:30 AM
  5. 20 valve trumpets/velocity stacks
    By brad in forum Technical - Questions
    Last Post: 13th March 2007, 08:37 PM
