Page 5 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 41 to 50 of 69
Thread: getting grip with your rear suspension
  1. #41
    Veteran ae71neo's Avatar
    Travis
    Blue Mountains
    What shocks in the rear Simon?
  2. #42
    Senior Member Simon-KE70's Avatar
    Simon
    TRD blue long strokes.
    may look into changing these rear shocks tho... im not all that happy with them
  3. #43
    Travis
    Blue Mountains
    Ah ok. Yeah im looking for shock upgrade in mine too.
  4. #44
    Simon
    was 12 and 6 lol, only cause the 12 springs were free and i was on a real tight budget, but with the cusco SW20 MR20 shock it ran real well and drove great. still, not the best hahaha
    i want to upgrade the TRD blue long strokes..what should i go?
  5. #45
    Veteran driftke70's Avatar
    Ryan
    Buderim
    will be good to hear about these bilsteins, as im planning my suspension pieces together at the mo and am tossing up between a few combos, got my heart set on hts though.
    wheelfriends.wordpress.com
  6. #46
    Simon
    are these off the shelf bilstines dave?
    maybe chuck me a set to trial i'm doing a private day at lala soon and will be taking a variety of susp parts with me to swap and change on the day to see what works and what REALLY works.
  7. #47
    Travis
    Blue Mountains
    Looking forward to the results!
  8. #48
    Ryan
    Buderim
    nothing beats seat of the pants testing,
    Can anyone see any improvements that i could make in my setup?
    Front 24mm bar,
    sigma lca
    40mm rca
    xt130 strut, cut spaced hts'd
    8kg ( i had 8s and they were a little stiff, but i think the smidge more weight of the 3s and w55 will make it a good choice)
    pillowball tops
    rose jointed castor arm with braced mounts,
    rear equal length 4 links,
    nose a SMIDGE below horizontal,
    5.5kg (f series)
    hts dampies
    18mm adjustable swaybar (whiteline)
    adjustable pan
    custom rca, about 15mm.
    car is braced with 10 point and various other braces,
    tyres are 195 60 14 semis up front
    185/195 60 14 on rear depending on rims fitted at the time, in something with a bit of tack not adrenalins unless i feel i need them later,
    i will be running my sway bar on the medium side of things, shocks will be firm in front, moderate in the rear, (moderate being probably stiffer than what agx go to)
    my driving style uses alot of weight transition and not so much hand brake or clutch kicking.
    i know i will probably end up changing stuff other than the shocks but, i was thinking maybe a slightly smaller front sway bar
  9. #49
    Dave
    The Ghetto
    the new design monotube blisteins sound gd with the new valving and heat protection technology etc. Was going to sell my trds and try these but then found out that the new designs had softer compression than kybs, which most people didnt like the feel off. I could be wrong though.
    Pending feedback from David @ ajps
  10. #50
    Senior Member s14seriesII's Avatar
    Mark
    Southern
    ive found mine can still go harder in the front
    im running 24mm sway bar with even shorter adjustment holes and stiffer than 8kg springs but when i lift the front r/c up it may be stiff enough
    obviously the rear in mine still needs to be sorted but it was kinda thrown together with what i had at the time have jic coil overs to go in the rear hoping to get bilstein to make inserts for them
    Owner built and tuned 9000rpm 402kw atw 3sGTE - AE86
    Quote Originally Posted by Beau View Post
    4ages are for the scared
  1. Grip suspension setups
    By Noddy in forum Grip and Tarmac Racing Section
    Last Post: 17th September 2012, 10:46 PM
  2. Replies: 15
    Last Post: 27th May 2010, 03:39 AM
  3. rear suspension
    By Stej in forum Technical - Questions
    Last Post: 21st March 2009, 01:13 PM
