Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 31
Thread: brake conversions/upgrades
    Senior Member sprinter666's Avatar
    Josef
    Blackburn
    Default brake conversions/upgrades
    Car - ae86
    part in question - front brakes, can include rear in anyone has info on how to convert t series drums into rotors?
    problem - want complete info on what brakes work, how to fit them ie rx7 conversion and wilwood 4pot upgrade, what size wheels you need for clearance etc.
    personal situation - running xt130 struts and thus brakes, and 14" wheels but have 15's on had to in necessary or i dont sell them, want to know if 86 brakes have same mounting as xt130? if not has anyone mounted bigger brakes to xt130 struts etc?
    hope thats enough info for some advice
    cheers, Josef.
    4-ac stock sprinter.
    Dec 2009
    Leigh
    Bayswater north
    I've got an rx7 brake upgrade for sale to suit sprinter/xt130 just need the brake lines made
    Josef
    Blackburn
    how much that go for? not in the market yet unless its in my price range lol and is it only brake lines needed?
    Dec 2009
    Leigh
    Bayswater north
    only brake lines yes. and 600 for everything
    Josef
    Blackburn
    aight ill get back to ya
    Senior Member Jip86's Avatar
    Lindsay
    Mackay
    ive got hilux calipers with peugeot rotors on xt130 struts and ive got about 4-5mm clearance with 15's.
    i have alot of room around the caliper just not much room at the front where the green thing is pointing.
    its more about the room at the back of the rim than the overall diameter.
    Aug 2010
    Geoff
    mt dandenong
    i've got bmw 2002 4 piston calipers and unknown vented rotors, calipers are a straight bolt on, have some mounts as factory 86 calipers. will get pics tomorrow
    Veteran timbo's Avatar
    Tim?
    Wild West
    Sounds very interesting!
    Mt Macedon
    There's about a million options here, most of which have been discussed in detail (apart from the BMW option above, that sounds new).
    - Keep your XT130 struts and use Hilux calipers and Peugot rotors.
    - Keep struts and use MX62 calipers and RA60 hubs and rotors.
    - Swap back to AE86 struts and buy RX7 adaptors and suited rotors.
    - Whatever else your imagination can come up with
    As for rear brakes, search Toymods for a thread by GA61XX about discs onto T series drum diffs.
    Aug 2010
    Geoff
    mt dandenong
    the bmw 2002 calipers as very similar to the volvo 240 girling 4 pot calipers. i'll get pics tomorrow. there is a bit of info on fitting the volvo brakes to toyota struts around the internet.
    im not sure what rotors i have, considering the calipers bolt onto the standard struts and fit under 14" watanabes im guessing the rotor size must be close to stock
  1. Brake upgrades.
    By --Redwork-- in forum Technical - Questions
    Last Post: 9th February 2009, 02:03 AM
  2. what brake upgrades do people do???
    By cjplow in forum Technical - Questions
    Last Post: 23rd June 2008, 07:29 PM
  3. brake upgrades
    By sprinters_r_mad in forum Technical - Questions
    Last Post: 27th February 2008, 03:15 PM
  4. Brake upgrades
    By eightsixboy in forum Technical - Questions
    Last Post: 1st November 2007, 12:43 AM
  5. Brake Upgrades.
    By wideslider in forum Technical - Questions
    Last Post: 5th May 2006, 12:51 AM
