I will take the clock if you can post it to sunny Brisbane. PM sent.
Found a few bits in boxes when tidying up - Will add more as I find things...
Need a Boss like a Boss? All suit Momo/Personal/Nardi (dual PCD) and are Toyota spline 86/82/70 etc.
AE101 Corolla cast ali with horn earth ring (65mm height*) - $25
SW20 MR2 pressed steel with plastic case (70mm height*) - $25
Random ali "drift spec" no horn wire or outer case - tie your bandana around Gotosan style (95mm height) hence only - $20
*These are OK for Corolla's but better with dished wheels, otherwise indicator stork needs to be pushed out to high-beam position or ideally 1" spacer for flat wheels to avoid knocking indicator with knuckles accidentally.
AE86 ADM/Zenki manual adj. mirrors fair condition for age. No cracks/chips in glass - $100 pair ($50 each)
Located in Adelaide Hills - Please PM for details or send me a sexy txt 0452-562-705 - Cheers KK
Sure no sweat! PMed
Clock Sold.
Stay tuned for more tales of interest!!
ADM AE86 Front Bumper (NO indictors) $150 OK condition. Couple light rubs on corners but no cracks or gouges...
Has been drilled to suit OEM front lip and flaps to bolt to arch trimmed back to allow max castor/wide wheels clearance.
*** For local pick-up will include a 400g can of Satin Black Bumper Primer to freshen up at your leisure ***
Pair front zenki Bumper Brackets $70 (or included with bumper above for $200 yo)
Little bit dusty but look pretty straight. Either respray them or mod for aftermarket front bar.
Buuy now get free spiders at no charge! JK blew them away with the Kärcher haha
Also have a pair of Power-Steering knuckles (allow more angle/lock) - $150
Update: Contact me on 0452-562-705 if you're interested in anything - Cheers KK
