Results 1 to 4 of 4
Thread: Interior and standard air intake plastics needed ASAP in Adelaide
    Member sidewayz_simon's Avatar
    Simon
    Baldivis
    Default Interior and standard air intake plastics needed ASAP in Adelaide
    Time to put the trueno over the pits, can anyone help me out with an interior and standard air intake?
    Willing to pay good coin if the parts are in good nick.
    Cheers lads.
    Senior Member Slimer86's Avatar
    Marco
    North Adelaide Suburbs
    Took mine through with a pod, so long as it is fixed to the body securely, and the idle up solenoid is connected to the pod after the filter.
    Also, if it's a Kouki trueno, you will have go through with clear indicator/parker light lenses (with orange globe for indicator) not the standard orange ones.
    Big up's for the North East Massiv'
    NSATB - New Skids Around The Block
    Simon
    Baldivis
    All sorted, and looking good. Took it in for it's ID check and apparently it doesn't have a compliance plate, so registering in it is going to be painful.
    Marco
    If it's a jap import, it won't have a compliance plate.
    Depends on how long it was registered in WA I guess.
    Have you got the import approval papers etc, to support it being an import model?
    Imports get a VIN number sticker once you have gone through ID inspection and roadworthy. (will be mailed out later on, and required to be affixed to the firewall)
    If it's a kouki model, you will need clear front indicator/parker lenses, else they will fail it.
    Not sure how it is on the Zenki, but I assume it may be the same.
    Other than that, the usual suspects here:
    Vehicles manufactured on or after (1/1/84 ADR 4D) are required to be fitted with Emergency
    Locking Retractor seat belts in all outer seating positions.
    You can register as only a 2 seat vehicle, but rear seats and belts must be removed, and cannot be re-fitted without another roadworthy inspection.
    And if it hasn't already been done, side intrusion bars fitted and signed off by a Chartered Engineer.
  1. (vic) air filter/ air box for ae86 w 4age needed asap
    By dove grey 64 in forum Cars or Parts Wanted
    Last Post: 11th October 2011, 07:29 PM
  2. Replies: 0
    Last Post: 2nd August 2010, 02:24 PM
  3. [VIC] WTB standard air intake
    By cbjaust in forum Cars or Parts Wanted
    Last Post: 7th May 2010, 01:48 PM
  4. WTB standard air box / cold air intake
    By snake in forum Cars or Parts Wanted
    Last Post: 2nd June 2008, 10:06 PM
