Page 10 of 55 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 ... LastLast
Results 91 to 100 of 546
Thread: 2AZ powered 86
  1. #91
    West
    Going to the workshop to do some more odd jobs on it today.
    I will finally fit the diff baffles and polish inside the manifold.
    Then the only things left on the mechanical package are the wiring and tune, tailshaft, and cutting away the new block for the starter motor clearance and tapping one hole for the BH union like the dummy motor. Oh and I need to make a vaccum manifold thats designed to spread the idle control air evenly between each cylinder. I have a design in mind but I need to fabricate it. Just basically a funnel shaped unit with the 4 nipples at the broad end and the idle controller feeding them at equal spacing from the narrow end, if you can picture it. Just deciding whether PVC will be high temp enough. Probably not, I want to bolt it to the inlet side under the manifold.
    Then its all just bodywork. One small tweak of the tunnel, fit the coilovers, n diff. Flare to suit some wheels. Then paint it and I can just build it like a man possessed.
    I might also invest in some tension control rods and steering knuckles from TTT at some stage.
  2. #92
    West
    Polishing came up a treat.
    Also faced the oil extender flanges.
  3. #93
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    where did you get that faced/cost?
    I need to do the same to my top rad outlet, atm it has a homemade thick rubber gasket to stop it leaking, but I don't think it will suffice for very long..
    BENT MECHANIX - Garage 20:
  4. #94
    West
    Did it myself on my disc sander wheel.
    Just bring it over. Or is it on your car?
  5. #95
    Niz
    South~Slide Briz
    ah nice, yeh its on the 86... can pull it off there though, not like the engine is going to be run... bit of a dick around to remove but it must be done I guess... you gonna be there sat arvo? its quite warped, reckon its cable of grinding it down flat?
  6. #96
    West
    Yeah its a 12 inch disc so that should be plenty large to flatten a thermo housing.
  7. #97
    Niz
    South~Slide Briz
    its steel though not alloy, is it capable of tackling that?
  8. #98
    West
    Yep.
    The pipe above is mild steel.
  9. #99
    Niz
    South~Slide Briz
    sweet, was thinking it looked like steel... you gonna be about on sat arvo?
  10. #100
    West
    Just give me a call, probably.
  1. The 4age powered Toyota 86
    Last Post: 18th December 2012, 11:36 AM
  2. 2AZ COP's - JJR recliner - rear shocks
    By biggo in forum Car Parts For Sale
    Last Post: 11th August 2012, 11:15 AM
  3. WTB: coilpacks + plugs off 1NZ, 2AZ or 1ZZ
    By Sam-Q in forum Cars or Parts Wanted
    Last Post: 15th February 2009, 08:09 PM
  4. 13b/13bT powered 86's?
    By jarryd in forum Technical - Questions
    Last Post: 30th November 2007, 01:01 AM
  5. Calling all CA18DET powered 86's
    By lowau in forum General Topics (No Technical Questions)
    Last Post: 21st August 2006, 11:06 AM
