Spent some time today putting the brakes and shocks in the uprights. Also bolted up the lcas and steering arms with the rcas.
Need to spot weld the perches then Ill put the springs and tops on to finish them off. I realised the fabricator has removed the brake line clips so I need to find a pair of those from some dudded struts to attach also.
Put a little atf in the struts to help dissipate heat between the shock and the strut upright.
Did the gland nuts up super tight with a 36 inch steel pipe wrench.
