Page 17 of 55 FirstFirst ... 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 ... LastLast
Results 161 to 170 of 546
Thread: 2AZ powered 86
  1. #161
    West
    So I split the Bigport n t50 apart to investigate whether things were rebuilt like the seller claimed or not. Once you look past the ten years worth of dust from sitting, the thing is actually rebuilt. I could see a new head gasket, clean oil (as in never driven on), new oil pump gasket, freshly sealed sump, new welsh plugs, I removed the top cover and saw that the shims and buckets were immaculately clean and the cam lobes have assembly grease on them. Its definitely rebuilt!
    The one shit thing is that they installed a mechanical oil pressure gauge and when they screwed the brass sender in they over tightened it and cracked the raised mounting bit where it threads in. However when It was removed the broken bits fell out and revealed plenty of thread to screw it into anyhow, so I dont think it will affect anything at all.
    On top of all this, the clutch was some heavy duty repco unit with a yellow pressure plate, and its also brand new and never driven on. Thank fuck I had a look before starting it, as there was a huge ball of grease sitting on the input shaft as if they over greased it to shit! If it had ever spun it would have flung out onto the friction surface and ruined it most likely, so a good catch there.
    All in all, between the suspension and the engine package, this car is fucking great! Im going to keep the motor and put it in a car some day, since I probably never will bother to rebuild a 16v unless its to learn about them, so it will be nice just to hold on to. Plus I drove Rians rebuilt one the other day and I was quite impressed by its manners and performance.
  2. #162
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    fuk yeah moving along nicely Matt... always enjoy reading the updates
    BENT MECHANIX - Garage 20:
  3. #163
    Veteran timbo's Avatar
    Tim?
    Wild West
    wtf on the oil pressure outlet... can't believe it would run a clear plastic line either!
  4. #164
    Veteran drift kid's Avatar
    Glossodia
    I space my steering column down too haha, 10mm packers to get it where I want it
  5. #165
    West
    Cheers guys.
    Motor and box dropping in today.
    Also just boght a rusty mark 2 rona with no motor or box to get a full kit of spares for the diff.
  6. #166
    West
    Another mad as fuck day of progress.
    Motor dropped in. Fits like a glove, and I do mean a glove. My tunnel mods are awesome! Right first time. Have all the right clearances around the steering. The slave and the starter are perfect where they are. I looked into a different slave cylinder but no need, same with the starter.
    Had to make a slight adjustment to the gearbox cross member with the die grinder to make one of the holes work, but that allowed me to move the gearbox tail to the left about 4 mm which enhanced steering clearance. Even with the motor in motion it should be sweet. Bolted on the trumpets and the throttles to see how it all looks. I think My Dmax bonnet wont cut it. I'm going to have to find a steel one and modify it as I need some serious bulging done. Its going to be a bit wild. One close clearance is the 4th trumpet is right next to but not touching the lid of the clutch master, however I can fit a remote reservoir against the bulkhead to make it tidier anyhow.
    I also made a little plate to close off the bulk of where the starter is cut into the block,its pretty neat actually. It really pays to have a 10 inch disc sander to round things off.
    I need to turn my attention to the fuel and cooling systems, then make an idle control system with a small air manifold to share it around.
    Also collected my diff bushing adapters so I can bolt the F series in tight!
  7. #167
    Seth
    I'm guessing you're aware of being able to remove the plastic reservoir from the clutch master and putting a dash fitting straight in?
  8. #168
    Veteran joeschmo_57's Avatar
    Joe
    NT
    Nightcliff
    Wow that has some serious lean. Is there a reason for that? It is it similar to factory?
    quit hatin get bakin!
  9. #169
    West
    If you read the thread Ive talked about the lean. It harks back to the ke70 with the slanted K, I kinda like it.
  10. #170
    Niz
    South~Slide Briz
    Rad mate, I love this creation your building, its gonna be awesome.... if you need a hand over a weekend at some stage just hit me up..
  1. The 4age powered Toyota 86
    Last Post: 18th December 2012, 11:36 AM
  2. 2AZ COP's - JJR recliner - rear shocks
    By biggo in forum Car Parts For Sale
    Last Post: 11th August 2012, 11:15 AM
  3. WTB: coilpacks + plugs off 1NZ, 2AZ or 1ZZ
    By Sam-Q in forum Cars or Parts Wanted
    Last Post: 15th February 2009, 08:09 PM
  4. 13b/13bT powered 86's?
    By jarryd in forum Technical - Questions
    Last Post: 30th November 2007, 01:01 AM
  5. Calling all CA18DET powered 86's
    By lowau in forum General Topics (No Technical Questions)
    Last Post: 21st August 2006, 11:06 AM
