Page 2 of 55 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 52 ... LastLast
Results 11 to 20 of 546
Thread: 2AZ powered 86
  1. #11
    north west
    Lolllllll! Mad ride dude!
  2. #12
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    sexy time in the google sack.
    FTP.
  3. #13
    West
    Cheers Clinton.
    I got a bellhousing for it today...
  4. #14
    West
    Ta Dah.
    I scored a w58 for it today too with shifter, yoke, speedo cable and crossmember still attached.
    So far this project owes me $950 and that includes motor, box, bellhousing and shipping the motor up from Melbourne.
Name:	rear of bellhousing.jpg
ID:	5987   Click image for larger version.
Name:	other side of bellhousing.jpg
  5. #15
    Veteran biggo's Avatar
    Nick
    Noosa
    What bellhousing is it?
  6. #16
    West
    SA63
    Not every bolt works, but by the time I get the starter in Ill have enough bolts to hold it together like it should be. Its kind of like the VZ pattern, which is based on S.
  7. #17
    Scammer, DO NOT BUY FROM ME!
    fairly keen to this all together
  8. #18
    looking good ! My only concern would be the just how tall it is. And being an allow sump... and the location of the oil filter ? Have you dummy fitted the engine yet ?
  9. #19
    West
    Hey Stu.
    Its not an alloy sump, its a pressed steel plate and its at the front. It needs slight reshaping to make it work, but not for clearance, more for oiling issues.
    I think the architecture of the block is such that it will fit over the crossmember nicely, It will sit a minimum 65mm taller than a 4age, maybe as much as 80mm in the worst case scenario.
    Theres no denying its a taller block, but if a 5sfe fits, this will fit. Its basically a motor thats designed to slot into a camry to replace a 5sfe.
    Im only a short time away from test fitting, and Ill probably mod the gearbox crossmember myself, and then start on engine mounts.
    As it is there is nothing on it that will stick out further or too much higher than a 4age dizzy with a kaixen cap on it. Im pretty excited to see how it sits.
  10. #20
    Nick
    Noosa
    big kev is EXCITED!
    no, wait.... I think he's DEAD
  1. The 4age powered Toyota 86
    Last Post: 18th December 2012, 11:36 AM
  2. 2AZ COP's - JJR recliner - rear shocks
    By biggo in forum Car Parts For Sale
    Last Post: 11th August 2012, 11:15 AM
  3. WTB: coilpacks + plugs off 1NZ, 2AZ or 1ZZ
    By Sam-Q in forum Cars or Parts Wanted
    Last Post: 15th February 2009, 08:09 PM
  4. 13b/13bT powered 86's?
    By jarryd in forum Technical - Questions
    Last Post: 30th November 2007, 01:01 AM
  5. Calling all CA18DET powered 86's
    By lowau in forum General Topics (No Technical Questions)
    Last Post: 21st August 2006, 11:06 AM
