Page 6 of 55 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 ... LastLast
Results 51 to 60 of 546
Thread: 2AZ powered 86
  1. #51
    Gone
    Joel
    Picton
    Impressed, what box did you go with?
  2. #52
    West
    w57
  3. #53
    Veteran timbo's Avatar
    Tim?
    Wild West
    You've been busy Matt, looks good.
  4. #54
    West
    Thanks Tim, I was able to set up the 6 rib belt with the standard tensioner and no extra pulleys, so now I need to find a chamber for an airbox. Thinking Reverie Zolder Macau Carbon box from Europe, but its looking like costing close to $700 by the time its shipped here, its perfect though.
    I have dropped off the oil pickup to be extended by Zenith engineering in Milton. Having it done with mild steel mandrel pipe. Hopefully get it this week aswell.
    Then I guess I can look at the cooling system. Im starting to consider making the outlet pipe from behind the head run under the inlet with an external pipe, as there is a tonne of room and the exhaust side will already have the in pipe. The I can use an easier to find radiator with one left and one right outlet. I have only found about 3 radiators with left hand only inlets/outlets. Most are either right hand or one left and one right.
    Then once I know the mechanical package can be fitted in, I will look at reworking my F series diff to have ae86 mounts and disc brakes, most likely from a corona I guess. The Ill need the tailshaft made.
    I guess I need to sell a couple of lips so I can afford to do the diff mod and tailshaft and buy an airbox.
Name:	zolder macau (2).jpg
  5. #55
    West
    Got my trumpets in the mail.
    Sam Q did a great job attaching them to the baseplates.
  6. #56
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    got an ETA on this beast Matt?
    BENT MECHANIX - Garage 20:
  7. #57
    West
    Nah. Just whenever it goes.
  8. #58
    Niz
    South~Slide Briz
    cool, keep hacking away mate..
  9. #59
    West
    Guess I need to put it into the chassis and investigate the tailshaft situation.
    Still a lot to do:
    Tailshaft
    Modify the diff for the chassis
    buy lsd for it
    redo the brakes on it.
    fit the pistons, mod the good block like the dummy block, cut away for the starter, tap some holes.
    collect and fit my custom coolant and oil pickup lines. Fit them up.
    wire it
    buy the ecu
    work out the best mapping for the vvti and tune it
  10. #60
    Gone
    Joel
    Picton
    its gonna be great when its finished
  1. The 4age powered Toyota 86
    Last Post: 18th December 2012, 11:36 AM
  2. 2AZ COP's - JJR recliner - rear shocks
    By biggo in forum Car Parts For Sale
    Last Post: 11th August 2012, 11:15 AM
  3. WTB: coilpacks + plugs off 1NZ, 2AZ or 1ZZ
    By Sam-Q in forum Cars or Parts Wanted
    Last Post: 15th February 2009, 08:09 PM
  4. 13b/13bT powered 86's?
    By jarryd in forum Technical - Questions
    Last Post: 30th November 2007, 01:01 AM
  5. Calling all CA18DET powered 86's
    By lowau in forum General Topics (No Technical Questions)
    Last Post: 21st August 2006, 11:06 AM
