Page 8 of 55 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 ... LastLast
Results 71 to 80 of 546
Thread: 2AZ powered 86
  1. #71
    Veteran stahlz_ae86's Avatar
    Paul
    Pete is running 15x7 +12 superlites and for me to run 15x7 +0 rewinds I will need a 2mm slip on spacer. The rotors are rda7103s I think, slotted and vented. Discs need to be bored out to 73mm and re-drilled to suit the Celica hub. What wheels were you planning to run on this rig?
  2. #72
    West
    Realistically my southernways 15x8 -8.
    They have about 10-12mm spoke clearance, wilwoods just clear them without spacers.
  3. #73
    Paul
    I know 15x8 Rota RKR's clear and in theory the 15x8 -4 superlites should also clear. I'll make a template to pop in the back of the wheel I think and upload it as a PDF file if I set it up as a group buy. Another possibility I have looked at is using an XT130 hub with the RA40 strut and exact same caliper bracket, but boring the disc out and redrilling to suit the corona hub. A spacer will need to be run between the rotor and back of hub but it takes about 7mm out of the x-factor wheel fitment problem.
  4. #74
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    nice update Mr Matt, cruising along nicely it seems.... I was silently hoping I'd spot my beast in the background somewhere (if that's the workshop?) haven't seen it since it was dropped off..
    BENT MECHANIX - Garage 20:
  5. #75
    Glenn ke_70's Avatar
    Clay
    Barossa!
    is that copper tube your using as brake lines?
  6. #76
    West
    Why does everyone ask that.
    Its cadmium plated steel. The flare nuts are brass.
  7. #77
    Clay
    Barossa!
    needs alittle sticker saying chillout it's not copper haha
  8. #78
    West
    Yes I do. haha.
    Progress has stalled until I can get my coil overs finished and back in my possession.
    I test fitted the Celia fans today, too fat, and they fit really poorly on the alloy radiator, so I have no choice but to make some of the after market ones work.
    I somehow have acquired about 3 or 4 different after market thermo fans. I really only remember buying 2. Objection, relevance, sustained.
    So I guess its time to pull the motor and set it up one last time once and for all. There's quite a laundry list of things I need to do to get the new block ready to bolt in. Drill holes, tap them, stitch drill and cutaway the starter clearance. And I need to get the flywheel modified so it fits on.
    Back at her tomorrow I guess.
  9. #79
    Niz
    South~Slide Briz
    keen.................. do it
  10. #80
    Senior Member turn69up's Avatar
    Apr 2010
    Laurence
    Northside
    I dont look at build threads much but noticed ur user name and had to have look see and glad i did awesome write up read the whole thing anyways thanks for the struts and was nice meeting u Matt (=^x^=)
  1. The 4age powered Toyota 86
    Last Post: 18th December 2012, 11:36 AM
  2. 2AZ COP's - JJR recliner - rear shocks
    By biggo in forum Car Parts For Sale
    Last Post: 11th August 2012, 11:15 AM
  3. WTB: coilpacks + plugs off 1NZ, 2AZ or 1ZZ
    By Sam-Q in forum Cars or Parts Wanted
    Last Post: 15th February 2009, 08:09 PM
  4. 13b/13bT powered 86's?
    By jarryd in forum Technical - Questions
    Last Post: 30th November 2007, 01:01 AM
  5. Calling all CA18DET powered 86's
    By lowau in forum General Topics (No Technical Questions)
    Last Post: 21st August 2006, 11:06 AM
