BRAKE PADS
Article adapted from an original article by Thomas Hall.
Reproduced by courtesy of Brake & Front End
At most workshops, the person ordering brake pads is given the choice of a several levels of brake pads. The good, better and best marketing is sorted out by price and brand rather than solid engineering data. Sometimes the mechanic has no choice when the choice is dictated by the reseller who only stocks certain brands.
In today’s brake friction market, many resellers put margin before technology and performance on the parts ordering screen. This can leave the person ordering the pads in a difficult position when his goal is to select the right brake pad for the safety of his customers. Also, what effects can a replacement brake pad have on the ABS, traction and stability systems?
ABS, TCS and ESC
Everybody who installs or orders brake pads should be asking themselves the following questions:To understand these questions and evaluate the potential answers, it is first important to have a basic understanding of the various chassis control systems the “wheel brakes” support and what are the operating principles and control strategies they employ. There are essentially five general chassis control systems available on today’s vehicles. On some vehicles they are standard and on others they are options available to the car buyer.
The Five Chassis Control Systems
The control algorithms for all these systems are extremely sophisticated and contain literally thousands of individual parameters that are tuned specifically to the particular vehicle line and brake system used on the vehicle. These parameters are developed, refined and tuned on a large variety of manoeuvres, speeds and road conditions.
It is certainly reasonable to wonder, after all the work to develop a fully integrated set of systems, what happens when a different set of friction material is put on the car, or more commonly, on one axle of the car during service?
To understand the potential effects, we must go a bit deeper into how these systems generally operate. In all of these systems, the computer controller (the brains of the system) is monitoring the vehicle watching for an indication that an undesirable operating condition starts to appear.
These systems closely monitor individual wheel speeds, vehicle deceleration, engine output, steering wheel angle, yaw rate, lateral acceleration and roll rate among many other secondary indicators. The controller uses all of this information to determine very precisely what the vehicle is doing compared to the desired behaviour of the driver. Then a corrective action plan is determined. The brain then commands a “torque change” (or “torque” in engineering shorthand) to the desired wheel brake. The system can not directly control torque. It can only control hydraulic pressure.
The desired correction may be a torque increase, decrease or hold. An individual torque command is developed for each wheel independently. The hydraulic pressure in the brake system is multiplied by the friction level of the pad resulting in a torque being applied to the wheel.
Torque Confusion
The system, based on all the tuning and teaching that was used to develop the system, assumes that for a given pressure command, a given torque correction will result.
Remember it is torque that ultimately creates the desired vehicle reaction. By changing the pads to a material that has a different friction value, you have changed half the equation the system is counting on.
As a result, the system will not get the torque reaction it expects for an optimum result. All of these systems operate on what is called a feedback control principle. In simple terms, this means the system calculates its best estimate of the required amount of correction and applies it. It then watches to see if that estimate was effective.
If it sees that it did not get the job done, it calculates another correction and applies again. This cycle continues throughout the event. By the way, the system is checking its progress at the rate of approximately 100 times each second and employing corrective actions perhaps around 10-15 times a second in multiple directions.
When the friction value changes, which it will most certainly do with different friction material, the system will not get to the best correction as quickly as it was capable of when it had all of the parts it was expecting. In most cases, the system will learn and correct for the “error” the new pads have introduced. It just will take more tries to get there and take longer. This results in reduced efficiency by some measurable factor.
The systems will still operate and still provide substantial improvements in vehicle handling control and safety vs. not having them. They are highly adaptable, but they just won’t be as perfect as they once were. In most cases, this will be very difficult, if not impossible, to detect at the driver seat.
If you were to measure the true performance of the vehicle by things like stopping distance, amount of steering correction, amount of pedal feedback and more complicated things like yaw gains and manoeuvre entry speeds, you could expect to find measurable degradation under many manoeuvres.
Since the system is generally very good at minimizing these effects, it would be easy to be convinced that this is of no consequence and that you should not consider this as part of your buying decision when it comes to selection of brake replacement.
The ability to “copy” a friction material’s characteristics is a very difficult task under the best of circumstances. All service technicians should consider that the OEMs, the friction suppliers to OEM (like FMP the makers of Bendix) and developers of these systems have invested thousand of hours by some really smart and dedicated people and spent millions of dollars to tune these systems to their maximum capability and insure they work in absolute harmony with the rest of the vehicle.
While this is done in some pretty obscure and unfriendly environments at times, it is all done to ensure maximum performance and control in the blizzard, torrential downpour or when the dog jumps in front of your customer’s car. Any decision to compromise this balance should be given careful consideration. As a general guideline, we would offer the following few thoughts:
In the modern vehicle, the wheel brake is challenged to contribute to a great many vehicle driving conditions extending way beyond just stopping the car. The friction material is a very key element in this. To maintain the optimum performance, it is important to understand the implications of the choices that are being offered to consumers and help them make an educated decision.
We recommend you check the Bendix Brake Pad Application Guide for details of what brake pads to recommend to your customer.
