Results 1 to 4 of 4
Thread: 4age fwd clutch work for rwd?
    Mar 2012
    Andrew
    Aldinga Beach
    Default 4age fwd clutch work for rwd?
    just got my hands on a 4age to replace my tired old 4age, will the clutch on it atm work in my ke70?
    Yes but add a spigot bearing to the crank...
    Check the life of the clutch, might be worth spending 150 or so to replace it anyway?
    Mt Macedon
    Only issue may be flywheel size. If you currently run a 200mm and the clutch is for a 212mm fly then it won't work. But it is incredibly easy to measure this and see.
    Veteran Skylar's Avatar
    Ken
    Clutch, yes but for future reference, if you buy a clutch kit for an AE82(200mm flywheel), the throwout bearing in that kit will not work on T-50 bearing hub thing.
  1. will an aftermarket RWD w/p pully work on fwd w/p
    By slide86 in forum Technical - Questions
    Last Post: 4th January 2010, 09:07 AM
  2. fwd to rwd 4age
    By stylz in forum Technical - Questions
    Last Post: 10th June 2008, 09:07 PM
  3. WTB 4age rwd or fwd sa
    By superbmobile in forum Car Parts For Sale
    Last Post: 3rd July 2007, 02:49 PM
  4. 4age fwd->rwd
    By noobae86 in forum Technical - Questions
    Last Post: 20th February 2007, 04:03 AM
  5. rwd coversion to fwd 4age
    By mish86 in forum Technical - Questions
    Last Post: 17th May 2006, 11:43 PM
