Results 1 to 8 of 8
Thread: loom identification!
    Aug 2011
    luke
    qld
    gold coast
    Default loom identification!
    ok so i hav an ecu for my 4age and the part number is 89661-12150
    from what i gather its the jdm ecu
    the loom i have does NOT marry up with the 14p inlet on the ecu,the other plugs fit fine but not the one in the 14p
ID:	25208   Click image for larger version.
ID:	25207   Click image for larger version.
ID:	25206   Click image for larger version.
    Veteran Skylar's Avatar
    Ken
    You're using the wrong plug. The one that doesn't plug in serves wipers and some other stuff. The plug you need is still on the car of the guy who sold you the stuff or in an old camry somewhere that you're about to go and raid for the plug.
    Ken
    Aug 2011
    luke
    qld
    gold coast
    what do you mean!!!!
    Ken
    Old Camrys (SV21) runs the plug that you're missing. You go to a u-pull-it wrecker and cut the plug off and use it on your car. Wire colours are different but I think they're mostly there. If not just re-pin a few wires and you're good to go. Look up the pinouts on club4ag and wire it up and be doing turnouts in no time.
    Veteran Rice86's Avatar
    Richard
    Liverpool
    Lol the last Plug your after comes from the dash loom, the big fucker that runs along your driver side engine bay and under your dash that controls everything else..
    Go to a wrecker and find a corolla that cames with standard 4age bigport and chop the plug off the loom, the plug that you need that is and then read wire diagram and wire it up, don't forget to wire up your fuel pump..
    dose
    Aug 2011
    luke
    qld
    gold coast
    just going with that would i wire my fuel pump into the pin im replacing?
    Veteran slide86's Avatar
    Huw
    Hills
    the fuel pump trigger wire comes from that plug, but you dont directly wire a fuel pump to the ecu.
    use the Fc terminal on the missing plug to act as a negative latch signal for a relay......but prefferably you should have the proper circuit opening relay to activate the fuel pump......
  1. Differential Identification
    By mikare in forum Technical - Questions
    Last Post: 10th April 2011, 06:00 PM
  2. F Series Diff Identification??
    By Rip it in forum Technical - Questions
    Last Post: 7th July 2009, 09:00 PM
  3. Ignitor Wiring Identification
    By sirsprinter in forum Technical - Questions
    Last Post: 8th January 2009, 10:08 PM
  4. LSD Identification
    By julzy in forum Technical - Questions
    Last Post: 21st July 2008, 10:12 PM
  5. help dizzy identification
    By blu 86 in forum General Topics (No Technical Questions)
    Last Post: 28th October 2007, 08:13 AM
