example. drive it like you stole it
i think the worse part about that is cutting a hole on the chassi...Yes you can use that hole in future i guess...but there are other things you can do to gain power without cutting up the car
dose
Pick up Sydney
Pics can be sent by phone
Emails ignored
Texts ignored
Private numbers ignored
Wankers abused
i run mine lpg and it has equivalent to 110 octane fuel. pretty sweet lasts me a long time, i used to burn a can of oil every 3 weeks, but after using that moreys oil stabilizer stuff i havent burnt any oil and my car feels like the powers back. cheaper than a rebuild
its actually around 100RON
Unless you buy the straight propane from supagas. Modern LPG Runs heaps more butane than what it did a few years ago.
thats true, there are also two other garbage gasses in there that bring the octane figure down.
100% propane ftw, none of this butane stuff
Should be 50 50 mix with propane and butane but the key word here is should.
Propane = power
Butane = ecconomy
The other gases would probably for the smell.
the fastest mine ever went was on a tow truck.
only jokeing....well sort of. shaving the head works well.
DONT confuse POWER with OCTANE, they are associated but different,
I believe that the gas im supplied with contains a mix of cfcs and nitrous oxides, just for the fun of it, thank you mobile
