Results 1 to 5 of 5
Thread: info on fitting rear 86 calipers to series 1 T18 diff
    Aug 2010
    Geoff
    mt dandenong
    Default info on fitting rear 86 calipers to series 1 T18 diff
    anybody have any info on fitting some jdm 86 rear calipers to a t18 diff? handbrake cables need changing? need caliper mounting brackets? any other hurdles to overcome?
    Dec 2011
    Kerry
    Warradale
    pretty sure that the backing plates are a different bolt pattern as the first hurdle, second one you might come across is the caliper fouling on the shocks
    Veteran Skylar's Avatar
    Ken
    The backing plates are nowhere near bolting up. S/T/F/G diffs are rectanglular axle tubeflange bolt pattern but disc diffs are like a trapezium(? I think that's the shape). Cables need changing too.
    Get some caliper brackets made that uses s13 calipers and discs as parts are far more plentiful. It's not too hard to adapt the s13 gear, I just had to make a bracket to hold the cables up in the tunnel and drill out the cable splitter to 10mm, I think.
    Or it'd be easier to bolt in a disc braked diff.
    Aug 2010
    Geoff
    mt dandenong
    lol i've already got the jdm rear calipers/pads and rotors coming in the mail. just dont have caliper mounting brackets and handbrake cables. i''ve read that going to corona rear ends is the easiest. so im most likely going to have to machine up a new type of bracket to make it work. odd there is so much difference
    Mt Macedon
    Forget JDM discs onto a drum diff. Far easier and cheaper to get a full Corona setup (from Pick-a-part) then mess with a custom backing plate. Plus you get a decent handbrake in the end too.
  1. S and T series diff info
    By slide86 in forum Technical - Articles
    Last Post: 1st July 2016, 08:12 PM
  2. Replies: 4
    Last Post: 25th June 2012, 03:26 AM
  3. Replies: 1
    Last Post: 11th March 2012, 09:08 PM
  4. t series diff, rear t18 bar, te72 parts ADL
    By -elliot- in forum Car Parts For Sale
    Last Post: 17th May 2010, 12:06 AM
  5. Info on F series diff ratios above 4.3
