Page 4 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 31 to 40 of 105
Thread: Shockworks Toyota AE86 Coilovers with stub axle Thread
  1. #31
    Senior Member turn69up's Avatar
    Apr 2010
    Laurence
    Northside
    What are these stubs made from 4140? Are they bigger to accept a bigger diameter strut/damper/shock? What spring rates do u offer im looking for around 10kg front and 8 rear, can ur dampers handle these spring rates, do u make ur own springs?
  2. #32
    Veteran shift_rook's Avatar
    SE Burbs
    They have been made to fit our strut. They will not be sold seperately. One of our Korean partners makes the springs, they also are an OEM supplier for GM and Hyundai. 10/8 is far to stiff. if you were running full competition race slicks you could possibly go up to an 8/6 or maybe even a 9/7 but 10/8 is ridiculous. We use a 6/4 package and this works perfectly, even with our competition cars, the damper works a lot harder so the springs don't have to.
  3. #33
    Apr 2010
    Laurence
    Northside
    Ye im not asking to buy them seperate just asking if u know how and what there made of (cast, forged, cnc'ed, 4140?? Etc) also i will be running full slicks so u do 9/7 then?
  4. #34
    SE Burbs
    It'd be difficult to do a 1 off order for the spring in the rear. Being that it is a custom sized spring. Also we haven't valved our package to suit that kind of spring rate and to be honest, i can't name many Australian circuits that don't have imperfections in the surface, also from my experience testing with higher spring rates at different circuits, it gives us push in the low speed corners and hairpins. You want slow progressive roll, with that high a spring rate you will have little to none. I'd love to see your build thread to see just what kind of car you're building here. I'd happily increase damping to keep the car more sucked in through the corners, though i would prefer to leave spring rates as they are.
  5. #35
    Moderator Frak's Avatar
    Jamie
    Good to see you are using realistic spring rates, I always have a laugh at the "I want 10/8", I've been using 6.5/4.0 for years and it works a treat on the circuit.Good work.
    Hachiroku since 1994
  6. #36
    ryan
    pm'd
  7. #37
    SE Burbs
    I now have a time from the supplier, more time than originally expected but they have taken care to make sure this stub is perfect. They have given us a time of 20th of September. Meaning all our Australian customers should receive their kits by the end September.
    I will now be sending a message to all the people who showed interest.
  8. #38
    Will be well worth the wait...
    Great job on this Chris, looking forward to my set arriving.
  9. #39
    Apr 2010
    Laurence
    Northside
    Ok well if in a couple of months i will be looking into coilovers and if u can figure out how/what the stub axles are made of and can/willing (ur a bit vague) to revalve and 9-7 or 8-6 at least and they go super low then i will defs get these and mabe later down the line get another pair with ur valving/spring rate u recon is best for time attack as thats what i wana do with it but want it on its nuts right now
    (=^ェ^=)
  10. #40
    SE Burbs
    At this point in time we're so busy in development we don't have time to develop a damper with the higher spring rate in mind, please take into account this is a different damper from the norm and we have found from our experience that the higher spring rate really isn't needed as it affects the car to much in the slower corners. In regards to materials the Manufacturer is currently looking into the best option, i'll be letting you know when i am told
  1. Shockworks Toyota AE86 Coilovers Suspension
    By shift_rook in forum Shockworks
    Last Post: 30th January 2015, 04:43 PM
  2. Bent stub axle
    By turn69up in forum Technical - Questions
    Last Post: 26th June 2012, 12:13 PM
  3. 1 AE86 Coilover set complete with stub axle
    Last Post: 18th June 2012, 10:45 AM
  4. Stub axle/strut bracing
    By AJPS in forum AJPS
    Last Post: 25th November 2010, 05:32 PM
  5. need a stub axle bad!
    By crackett in forum Cars or Parts Wanted
    Last Post: 25th January 2007, 03:39 PM
