yes, it's starting to be a common conversion
Good Info.. Could the 5v could be split to feed to coils? or it will be to much and the volt will drop causing it to not to trigger them?
sam-q do you only make a valley cover for 20v or also 16v?
coilpack adapter plate?
no only 20v, I was going to make it for the 16 as well and I only needed 5 people to say yes in advance and I would of done it but no just one or two.
Saw on club4ag u made some?? R they ready now?
yes things changed quick:
$150 inc all bolts
send me a PM if your interested
is there any variation between small port and big port cam covers etc?
I will send you a PM instead so things don't go off topic
you can use the big port valley cover on the small port cam covers, same bolt location just a little taller
allowing you to use the taller coil
Cheers Kieran
Thanks to: Az & me - Azcustom
John - Davidson Autobody
Matt - Tasmanian Engine Reconditioning
Tobias - Koolstik Signs
4AGTE Powerd AE86 Tassie Spec Build Thread
also 227 coils are used on the fwd beams as well as caldina like anthony said
the beams now uses 39 coils as the 36 no have been stopped from production ,you would just have to change dwell time like anthony said or you can use 227 which is the same as 39 coils anyway
