Results 1 to 10 of 19
Thread: Are AE82 struts and hubs the same as AE86?
    May 2012
    Craig
    Queensland
    Scarness
    Default Are AE82 struts and hubs the same as AE86?
    OK I've searched for hours and can't find an answer to this one...I need to know if they are the same, and if they aren't, then are AE82 hubs the same as AE86?
    Probably a noob question, but I have to start somewhere
    Moderator Sam-Q's Avatar
    Endeavour Hills
    no front wheel drive toyota strut is compatibable with a rear wheel drive strut
    May 2012
    Craig
    Queensland
    Scarness
    Ah...didn't even think of that. How embarassing but thanks.
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    Yeah, they are the same......
    You can use those struts, VH commodore Tailights, Pulsar rear diff, and that will enable you to bolt a Cresta Turbo 2.4L Diesel motor straight in, and you can even still use the Auto box......
    I recomend you change the spark plugs and change the clutch too.0...
    May 2012
    Craig
    Queensland
    Scarness
    Yeah yeah I know what a dick. You may be surprised to learn that I dont actually know anything about Corollas
    JoJo
    ACT
    Tuggeranong
    You can tell that from the question........
    Good luck with whatever you are attempting....
    Gunner
    Oh my.
    Moved to correct section... Was originally in technical questions
    Senior Member Dylan's Avatar
    Dylan
    Surprised no pics yet
    AE82
    AE86
    JoJo
    ACT
    Tuggeranong
    only a few mm differance........ Should fit
  1. AE86 Front Struts and hubs
    By Bomfunkmc in forum Car Parts For Sale
    Last Post: 18th May 2012, 07:29 PM
  2. ke70 hubs on ae86 struts
    Last Post: 7th April 2010, 04:40 PM
  3. Ae86 hubs or struts
    By ke_70 in forum Cars or Parts Wanted
    Last Post: 6th April 2010, 01:41 PM
  4. Ae86 Struts and Hubs
    By google1304 in forum Cars or Parts Wanted
    Last Post: 30th August 2009, 12:55 PM
  5. Replies: 2
    Last Post: 27th December 2008, 07:00 PM
