Results 1 to 4 of 4
Thread: ECU Diagnostic code 5
    Veteran timbo's Avatar
    Tim?
    Wild West
    Default ECU Diagnostic code 5
    Hey everyone!
    I have recently fitted a switch for diagnostic mode to make it easier to check any problems when I start the car. A n a l I know...
    Anywho, it has thrown up an odd code, 5 blinks, a 4.5second break then another 5 blinks. I can only work it out to be 5 because the 4.5second space indicates the end of the code before it repeats it.
    There is no code 5!
    Anyone have an idea? I am going to reset it tomorrow morning and see if it disappears. I also find it odd that the Toyota manual skips 5; 4 straight to 6.
    Veteran Nikkojoe's Avatar
    Tom
    From memory that is usually O2 sensor, but I could be wrong.
    EDIT: Looks like i might be right
    Steve
    I know from my old ecus there was a difference in the codes thrown for the same error. Some ecu's throw single digit codes and others throw 2 digit codes, why? i dunno but it happened.
    But if i had to guess id say Jap ecu's throw double digit codes and aus ecu's throw single and i couldn't tell you why.
    Tim?
    Wild West
    Ah ok, probably makes sense to be o2 sensor, should have googled...
  1. wtb toyota 20v diagnostic plug
    By matho in forum General Topics (No Technical Questions)
    Last Post: 26th June 2012, 07:47 PM
  2. 4age diagnostic mode
    By extra_anchovy in forum Technical - Questions
    Last Post: 24th May 2011, 10:38 PM
  3. Replies: 5
    Last Post: 22nd March 2011, 07:07 PM
  4. 4age diagnostic code 12
    By geoff in forum Technical - Questions
    Last Post: 22nd March 2010, 09:58 PM
