what state of australia?
Not a cheap job unless your good at fabricating
hey guys,
just a question about engineering a 20v into a ae71.
because my model has the 4ac 1.6 by putting the the 20v i'm not upgrading the capacity. so i wouldnt have to upgrade my brakes or anything. and being a bolt in modification engineering will be fairly cheap, correct?
anyhelp greatly appreciated.
ben.
i;m in melbourne.
But, i know your the man to see about all 20v stuff lol
Is there alot to be modified for it to fit?
i am even considering 16v 4age. not gonna be a race car just daily/skidder
ben.
vic = trouble
I can give you the full list of whats required by law and its isnt pretty. Before someone tears your head off I suggest have a good search on the forums for 20v conversions. I can sell you the parts for the cooling system and for everything else go here:
I suggest a basic 16V conversion
Thanks champ.
is what i've been told about the capacity laws correct tho? because really all your doing is putting a efi head/setup on it. or is there more to it?
ben.
been to afew places to get quotes for my 4age into ae71:
quoted $550 for carby to efi conversion (4ac > 4age), but u needed to get a weight bridge cert, engine check that have been signed off by a rwc mech and a 02 check by exhaust or rwc place.
Also depending on engine power, brake upgrade may be required (used ae86 front brakes into ae71)
got another quote for engineering for the whole car @ $800
doesn't matter if u put a 4age, 4agze, 3sgte, 1uz, remove rear seats, roll cage, rx7 front brakes, diff conversion, etc..
its $800 for the whole test
thanks rhty.
im not going to be putting a cage or nothing in it just a stock 4age.
i'll do the conversion myself (mechanic)
was thinking of using brakes off a ae82 or something like that.
i had never heard of the "weigh bridge" before tho....
yea the dood said they needed to put down the new weight of the car with the new motor/equipment
choose jdm ae86 brakes cos they bolt in + aftermarket parts for the struts
did you have to upgrade any suspension in order to pass? did you leave drums on the rear aswell? ben.
as far as I know you only need to upgrade front brakes.
I was told by an engineer they have to check all the safety side of things
Emission's comply with the year of motor your installing
car stops in some standard stopping test
DB from exhaust complies
weight of car in comparison to brakes and
and the car has to be all round road worthy
most of the info you need will be here
