Nice find...
Was on my way back from Melbourne the other day --- thick fog for the 1st two hours on the road --- pulled over to have a coffee and bugger me if I didn't find this on my trailer !!!!!!!!!!!!!
ONLY THE GOOD DIE YOUNG ------ I MUST BE VERY VERY VERY BAD
AE86 4AGE 16V N/A TRACK CAR ( RED )
AE86 ROLLING SHELL --- IN CASE i F-CK UP !!!!!! (PRIMER )
AE86 ADM UNDER CONSTRUCTION ( STREET CAR) 4AGE 16V , (RED )
AE86 Trueno ( RESTORE TO PERIOD GOODNESS ) White
AE86 4AGZE Wreck ( to be rebuilt into Khannacross fun car )
KE 15 x 2 -- SPRINTER ( RESTORE TO PERIOD GOODNESS ) RED
TE72 (T18) X 2 BIT OF PAINT , BIT OF MECHANICAL way we go RED
Soarer 1995 1JZ Factory 5speed (R154 )
Nice find...
specs? info? ideas? plans?
Hope it was still there when you got home with just oki straps holding it on! ;-)
looks set for dirt fun....? You didn't have one of those in the collection list and needed to fill the gap?
that was on grays online right?
Yeah , grays online --- funny story !!!! I wanted the Grey AE86 one in SYD , much better car ( If new owner is on here let me know how good ) . Well never bid on Grays before ,this was up 1st so did a practice bid , then chased the grey car , I gave up at $3800 and it went for just under $5000. Then went back to see how much the yellow one went for --- bugger --- no one else bid , oh well was only coulpe of G . ( road trip to Melb ) Had some stuff to pick up from a mate anyhow.
I new it was rough !!! 4ac , front radiator support cracked , bit of panel damage , some misc Borg Warner rear end ( think it will be a bin job ) etc etc , cars had a hard life . But has a well built full cage , bilstein shocks, 6 point harness , race seats and no rust found yet ,in fact has had a full body respray. Also as I first approached the car noticed a few items inside the car that had not been listed .
10 - Aust std Race helmets
18 - h/d saftey cones ( witches hats )
1 - 2500 watt petrol generator + 8m of power cords
WHAT AM I GOING TO DO WITH IT ??????????????
Not sure yet , but she still has good life left in her as a dirt race car , needs bit of TLC and an engine transplant ( found a healthy small port 4age with loom ,ECU and all plug ins very cheap while in Melb , so that may go in with a locked t series rear. Plenty of time to pussle on what to do . Can't get it in the shed till I finnish the Roadie rebuild and it is just a primer shell at present .
Plus Track car requires a bit more TLC before next event , son's roadie has an exhaust leak and just bought a 2nd hand 6x3 shed , so got to level some ground , put down a slab and rebuild it .
So yeah got a bit on , hardly enough time tp scratch my arse.
If these things just pop up on your trailer Bob, you should go on more drives......![]()
