Results 1 to 10 of 11
Thread: WTB: 20v components, A/C and P/S
    May 2011
    Van
    SE
    Default WTB: 20v components, A/C and P/S
    Hey guys after, A/c and P/S for 20v, with the brackets
    thanks let me know what u have
    ACT
    Compton
    Hey van, I got Aircon in my trueno, thinking of taking it out, would it suit or is 20v different? I have bigport
    Moderator Sam-Q's Avatar
    Endeavour Hills
    I have an air con bracket that suits a 20v compressor and has been modified for RWD for $20
    May 2011
    Van
    SE
    Johnie does ur trueno have powersteering?
    May 2011
    Van
    SE
    Sam: would the 20v compressor fit the standard lines?
    ACT
    Compton
    Yeah it has power steer, cbf taking it out though
    Nigel
    I have an aircon compressor, p/steer pump, and all brackets from a 20v fwd engine if this helps.
    Endeavour Hills
    now that I don't know, I would image so, however the fittings are steel and the compressor aluminium which means they can very likely be wound out and swapped should the need arise.
    May 2011
    Van
    SE
    mm, i guess i gotta do a bit of research,
    i have the 20v using 16v power steering setup atm, just wanting to install aircon
    Endeavour Hills
    I covered this in the other thread how I managed to adapt 16V gear with some mods to the 16v crank pulley and fitting it
  1. (QLD) WTB: T50 gearbox and associated components.
    By milan_ke70 in forum Cars or Parts Wanted
    Last Post: 28th November 2012, 08:53 PM
  2. Suspension components
    By beaudayo in forum Technical - Questions
    Last Post: 1st July 2012, 10:44 PM
  3. Wtb: any ae86 a/c components
    By DR86FT in forum Cars or Parts Wanted
    Last Post: 21st April 2012, 10:06 AM
  4. wtb: rwd loom, rwd exhaust manifold, rwd water components, rwd inlet
    By dove grey 64 in forum Cars or Parts Wanted
    Last Post: 4th September 2011, 03:18 PM
  5. a few sc12 components
    By callum1 in forum Car Parts For Sale
    Last Post: 26th May 2008, 08:07 PM
