1977 RA28 Celica
Engine:
... SR20DET Red Top
KKR380
650cc injectors
Power FC + Hand controller
Rocker Stoppers
Z32 Flow Meter
600x300 FMIC
Twin thermo fans
Bleed valve
S/S low mount manifold
S/S Dump pipe, modified
S/S 3” Front pipe, 3" Side pipe
070 Bosch Fuel pump / surge tank
Pod Filter
Alloy catch can
S13 5 speed with short shifter
HD clutch
Suspension:
Front:
S13 Coil overs
Adjustable strut tops
R33 4 Pots
R33 Vented, Slotted rotors
R33 Uprights, hubs
R31 LCAs - Modified
RA28 Modified adjustable Caster bars / Nilothaine rubbers
40mm Bolt on spacers
H/D sway bar
Rear:
7.5" Supra CIG Locked Diff/Housing with Rose Jointed Watts Linkage, Diff breather etc
Girlock Calipers
Braided lines
Unknown Springs / Shocks (still need to find good ones)
Body:
1977 Mustang back celica
Fully seam welded
Formula Blue
Front strut brace
Alloy Fuel cell
Relocated Battery
Interior:
Sports Steering
Sports Gear knob
Auto Meter Boost Gauge
Oil pressure gauge
water temp gauge
Power FC hand controller
Race seat / 4 Point Harness 2”
6 Point alloy cage
Wheels:
15x8 V4's +14ish
15x9 V4's +20ish
Unfinished project -
0420371380
Will help get interstate
photos to come, here is one:
$8500 ono NOW TAKING OFFERS SOLD
Comes with lots of spares also.
To get this car running and driving you would need to do the following:
1)Wire up the ECU, Fuel pump, Ignition, Starter, Alt and gauges. (the correct engine / ecu looms are in place)
2)Bleed the brakes (I would upgrade the M/S though with a supra one)
3)Bleed clutch (install the slave cylinder)
4)Install a prime pump for the surge tank (a VL external will work well), or bipass the surge tank and just direct feed the engine with the exsisting bosch pump.
5)Add coolant to the radiator and oil to the engine.
Remember, this car has not moved from the corner of my shed since 2008 until I took some photos last weekend. It does not present well and is very dusty. With a fresh 2pak paint job and some chrome around the windscreen (supplied) it should look a million bucks.
THIS CAR HAD A CAMS LOG BOOK - YES, THE CAGE IS CAMS APPROVED! was logged with a 3sge+t not a SR20DET
