Results 1 to 9 of 9
Thread: Smallport AE71 Overheating issues/cluster issue, well I think so
    Senior Member pauliee's Avatar
    May 2011
    Paul
    Wollongong
    Default Smallport AE71 Overheating issues/cluster issue, well I think so
    hey there guys,
    Car - AE71
    motor / part in question - Smallport 4age
    problem - Overheating
    i realise this has been covered before, but the threads were rather old and lacked any conclusions.
    The issue is im currently having is my smallport will gradually overheat. Over approx 10-15 minutes the car will gradually rise to the last point on the gauge.
    Im using a alloy radiator, as well as new genuine water pump and all new gaskets.
    The thing thats confuses me is , if I take it for a squirt, on an uphill slope, the car temp gauge will drop, and vise versa on the downhill it'll rise. the gauge seems to rise and fall as it feels fit. I've replaced the thermostat and tested it prior in boiling water. As well as this, if i drain the radiator after driving it from the bottom valve, the water is not overly hot, say luke warm. My mate also mentioned he doesn't think its even up to pressure.
    Which leads us to question whether the clusters playing up. Prior to the conversion, the dash worked 100%. Since then, the dash clock and backlight are not longer working, and speedo will fidget when the either indicator is switched on, as well as when the left or right indicator lights flicking in time, no matter which indicated (left or right) is pushed.
    So i guess im asking whether anyone has had a similar issue, and wether its sounds to you buffs if it is mechanical or an issue with my cluster/sensor/dash wiring.
    cheers,
    Jake
    Northgate
    Might be a cluster. Not a car but with my bike I thought the temp gauge was stuffed so I put a digital aftermarket one on and found out it was the gauge was stuffed.
    Weird that it'll drop and rise like that.... The temp gauge needs to be earthed for it to accurately get a reading... As soon the gauge starts to get a reading if it isn't earthed it'll rise until it maxes out the gauge. Having said that it usually stays there, but i've never left it maxed out so i wouldn't know if it drops / rises etc.
    It'll be a brown wire or white/black striped one which was previously earthed but no longer is after you swapped the engine harness out.
    If you get stuck I could prob swing by sometime to sort it out... Pending good surf reports.
    Veteran timbo's Avatar
    Tim?
    Wild West
    Surely you could physically tell if it was overheating? Just chuck a multimeter on it and check the manual.
    Jun 2012
    rami
    nsw
    sydney
    I had a similar problem were after 15 min the car will start to overheat then wen you drive it starts to cool down and wen you stop it startes to rise again
    my problem was radiater fan it wasnt spinig fast enought over time the fan was dieing. Also have a look at the radiator cap.
    May 2011
    Paul
    Wollongong
    Wow guys, appreciate all the replies. Cheers Matt for the offer.
    Well guess, after scratching my head for the last two days, ive found the issue. After about 3 thermostats, countless radiator flushes and shit, different radiator caps, it ended up being the bloody tacho. Swapped it out for a spare and bobs your uncle we've got a proper reading.
    Anyone else has this issue, before you stress about the motor, check the tacho first hah!
    Tim?
    Wild West
    Goodo.
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    see this is funny, my cluster guage at the moment isnt connected to anything (wire is zip tied near sensor) my cluster guage goes up and and down as it pleases, changes with weather and hard driving
    May 2011
    Paul
    Wollongong
    ^ same issue, still have it. But mines all connected up.
    thinking about changing sensors.
  1. AE71 Smallport conversion spark issues
    By ke_70_blue in forum Technical - Questions
    Last Post: 8th November 2012, 09:14 PM
  2. Overheating Smallport 4age AE71- Headgasket?
    By pauliee in forum Technical - Questions
    Last Post: 28th September 2012, 02:01 AM
  3. KE70/AE71 tacho cluster.
    By Ben 1 in forum Car Parts For Sale
    Last Post: 3rd January 2011, 05:18 PM
  4. Ae71 cluster into Ke70
    By KePanelVan in forum Technical - Questions
    Last Post: 21st July 2009, 08:13 PM
  5. sr20det overheating issues (I KNOW ITS NOT A 4AGE)
    By Fozz in forum Technical - Questions
    Last Post: 22nd March 2009, 11:14 PM
