Awesome, the E85 tune is sooo much smoother throughout. Now to take the engine apart and build it to suit the turbo application for decent boost.
Castle Hill Performance Centre have recently finished development on a drive in / drive away turbo kit for the 86 / BRZ.
Components
Haltech Sprint 500 ECU
Garrett 2871 Turbocharger Running at 5.8PSI
Front Mounted Intercooler
Option to retain the Factory Airbox
Powdercoated Black Piping
Factory direct port injection controller
Scavenger Oil Pump
Dyno Dynamics Results
Stock Standard: As it rolled off the factory floor - initial dyno results yielded 103kw
Castle Hill Performance Turbo Charger Kit - 98 RON Fuel : An increase of 60kw at the wheels to a peak power of 163kw 5psi
Castle Hill Performance Turbo Charger Kit - E85 Fuel : An increase of an impressive 110kw at the wheels to a peak power of 213kw 8psi * Required haltech sports 1000 ecu and GM Flex Fuel Sensor*
Observations
The turbo is mounted very low near the gearbox housing, and is considered somewhat bad for most turbo installations. However, with the installation of a scavenger oil pump this issue was quickly overcome and the oil supply is well within tolerances.
The kit is extremely well put together and a non ethusiast would be forgiven for mistaking it as a factory option. The intercooler looks at home behind the front bar and if painted black would be easily missed as very few modifications were required to make it fit.
Over all it is a well assembled kit and the only real choice is to run E85 or 98 pump fuel.
Is E85 Worth the extra 53.2kw?
53kw at the wheels is definately a power increase that you will notice under your right foot. A few years ago, finding a petrol station that knew what E85 fuel is was near impossible, let alone one that actually supplied it. However, as the use of the fuel is increasing the petrol stations are starting to stock it and it isn't pretty easy to find somewhere to fill up these days.
Due to the nature of the E85 fuel, the alcohol content is significantly higher and it burns at a much faster rate than that of traditional petrol's. This requires the upgrade of your fuel injectors and the installation of a GM Flex Fuel Sensor as the fuel composition with ethanol changes significantly. As such the tune needs to be adjusted to suit, hence the installation of the Haltech sports 1000 ecu.
Ultimately you as the driver will need to decide wether you want double the power of a standard 86 or would be happy with only a 50% increase.
For pictures of the kit please visit
or enjoy the video below.
^ Agree totally...
Castle Hill Performances pricing is $9,995 drive in / drive away.
Thats not too bad.
Is that the eflex tune with haltech 1000 and 3" exhaust.
So... I heard that not long after this video was taken this car threw a rod through the block.
Then either the owner or Castle Hill Perf took all of the turbo gear off the car and tried to return it under warranty to the dealer.... lol
Warranty denied because they had to hack up so much stuff under the engine bay that it was obvious a turbo conversion was done
Can anybody confirm its the car in this video? Anybody know the owner or anything?
I wouldn't know what car your referring too but im not surprised by someone throw a rod thru the block.
Unless your tuning is spot on 100% of the time, 10+ psi, high compression + other unforeseen variables gives little to no room for error especially on stock engines.
LOL at returned for warranty, kudos for trying thou.
Bob can you reveal who you heard that from?
I also will check to see if any engine warranty claims have been submitted with Toyota for a hole in the block.
Throwing it out there
I picked up my car from Windsor Toyota yesterday and the service manager told me about this car and how they denied the warranty after a quick Google search of the plates brought up this video...
So I would call that confirmed
Former Cars: 1992 300zxTT ***SOLD***----------------1984 Daily 20v AE86 ***PARTED OUT*** =(
Current Cars:
Project Ugly Duckling - 1984 AE86 SR drift car ------------------Daily JDM Trueno GT-APEX hatch![]()
Thanks robbo... Confirmation , I wonder how the other turbo builds are going...
After my post questioning the validity of
the claims, I got a pm saying the owner is still looking for a replacement block and suitable pistons
it lasted just over a month @ 7psi
Ouch that's not very good at all, i wonder what the issue was, could of been a number of things really.
