this is how it sits at the moment, sorry about the shitty phone quality
Pm me about dash mat ,I dnt use it
I can't wait for 20v either.t50, crossmembers, peel box etc is all sorted just need motor
have to get a pic, ghetto next to the minta, make your thinglook even more clean
So clean, wheels and low looks good.
UPDATES!!!!
well a few weekends ago i finally put my 4a in
specs
-4age blacktop 122xxx kms
-t3 stacks
-t3 tall shifter
-SQ rwd water kit
-SQ vacuum block off plate
-4-1 headers,2 1/4" exhaust ,under diff, muffler at rear
-alluminium radiator , 12" thermo
-TRD clutch,standard flywheel
-t50
-tweak'd performance blacktop into sr5 loom (shes a gem)
-standard computer
suspension hasnt changed,coils and mk2's are next on the list
dynoed it,made 96.7kw but was leaning out near limiter,will get fuel pressure reg and so if that solves it
drove it for 2 days and lost my license for speeding and got yellow stickered(engine not complied and rear tyres bold) the standard shit we get picked on for
got defects cleared and now i can stare at it for 3 months
forget to mention,standard dizzy location, firewall has a recessed section about 70mm into cabin,room to still adjust dizzy will get photos up later
This thing looks so mint, How could you recess the firewall!
it doesnt look as bad as it sounds,the recess follows original curves of firewall ill have to get some close up photos of it
just before wiring,coil located behind firewall
firewall hacked!!!! 50mm strip welded in,backing plate has a 10mm roll all around
finishing off cooling system,kinda like it with no grill haha
another dyno shot, should get around to cleaning that hood
just before lowering car onto engine,gearbox and x members
