Results 1 to 4 of 4
Thread: 16v vacuum sources..
    Senior Member adds's Avatar
    May 2010
    Adam
    St George
    Default 16v vacuum sources..
    Hello so this may be a noob question so im sorry if it has been answered before. Couldnt find much info with my searches.
    I'm trying to figure out vacuum signals for my 16v GZE converted to turbo. (afm)
    So on my manifold there's a bolt type thing with 3 nipples comming off it. Will it be ok to run my FPR, boost guage and blow off valve off this? Doing it this way, it each item receive enough amount of vacuum to run properly..
    Also there are 2 nipples towards the front of the throttle body. From what I've seen people block these individually. Can these also be used as a vacuum source ?
    Any light on this will be aawsome.
    Senior Member sheppo's Avatar
    Sep 2011
    Karl
    Hallett Cove
    Hey mate.
    I'm running a 16v turbo engine
    The 3 nipples together.
    One is for my fuel pressure regulator
    The second one is for my MAP sensor on my ECU and the third goes to my boost gauge.
    The two at the front I have one blocked off and the other goes to my BOV
    But I'm not sure if I've set that up right as it doesn't seem to be working haha
    Hope this helps
    Veteran timbo's Avatar
    Tim?
    Wild West
    It will be fine to run off those nipples. Take the plug off one and put you finger there... it works!
    May 2010
    Adam
    St George
    Yeah ok might just keep the front 2 blocked and run the rest off the 3 nipple bolt thingo! Just wasn't sure if that would give everything enough vacuum or not.
    Cheers guys
  1. Vacuum block for ITB
    By evil86 in forum Cars or Parts Wanted
    Last Post: 23rd April 2012, 10:16 AM
  2. other options for vacuum...
    By fantapants in forum Technical - Questions
    Last Post: 28th May 2009, 06:37 PM
  3. Vacuum/Map Sensor
    By hugh in forum Cars or Parts Wanted
    Last Post: 17th December 2007, 12:29 PM
  4. 4age 16v vacuum diograms
    By HiLtOn in forum General Topics (No Technical Questions)
    Last Post: 1st August 2007, 08:05 PM
  5. why is the Vacuum hose not connected??
    By DK86 in forum General Topics (No Technical Questions)
    Last Post: 27th June 2007, 07:29 PM
