didnt spend as much time on it as i wanted to this weekend, just tidied up a bit of my mess and finished off the pedals
Been a while between unpdates but Uni is finished for the year which should hopefully give me more time to spend on this as I haven't touched it in a while now because I've had exams and stuff.
During the week I picked this up
Reduced: 93% of original size [ 1024 x 768 ] - Click to view full image
will be using this as my lift pump to surge tank 129lph low pressure pump.
Had a look over my wiring tonight and realized the interior light and the handbrake light on the dash were not hooked up so spent some time wiring those up. So the wiring is more or less done now, need to tidy up a little and that should be it.
Making good progress in the time you've had it should be a fun little car in a few months time.
what diff you planning on running?
R31 diff..
Post #10
Is that the standard ke70 castor rod I between the s14 ones?...
nah that's the standard s13 castor rod, Toyota use a different setup to the Nissan ones
Been a month or two since ive really done anything on this. Have been waiting on a heater core that I ordered which turned out to be the wrong one and then couldnt find another, so ended up just buying another wreck
So pulled the heater core out of that pressure tested it, fixed the leaks and put it in. So today i started assembling it all into the car and piece the dash back together. I also ended up cutting my new stereo into the top of the dash and wiring that up
plan is to spend some more time on it tomorrow. Want to start getting work done again!
No real achievement as the car been at this stage for a while just hooked a fuel pump to the battery and a jerry can to test if my a/c compressors getting power, which it is not but still feels good to have the engine running in the rolla for the first time
i love this build
---- Fryin Fifth Represent ----
