Leyburn and the funky ratios.
Sent from my SM-G930F using Tapatalk
The panhard.
Thanks for sharing the vid, nice gearing.
What happen to your engine, able to fix it?
Sent from my iPhone using Tapatalk
Bit of a strange 1. I will be taking the bottom end out/apart in the next day or so.
I was expecting to find a head gasket blown between 2-3 but the problem seems bigger than that.
Mixture and burn colour in the ports & pots look good. However, i think there has been some random spark issues. Big port dizzy is the most likely culprit.
I think I'm up for a new block and pistions.
I think I'm up for a new block and pistons.
What was the piston ring end gap set at?
Davew7
5thou/inch as Wiseco recommends
Lets us know what you find, once you pull the piston. It will be interesting to find out what caused it. Davew7
Well. The ring lands are intact. That kind of buried the detonation theories. I'm thinking a possible clearance issue?...
Off to see my machinist and engine guru in the morning. They have a wealth of knowledge!
