Yeah, I have wanted to do a "beater" style car for a while......
It will look haggard, but go fuckin hard........
Couldn't get too much done today, but did get time to pull the old 4AC out of the wags......
Ok, So, Gave the engine bay a clean and degrease, and it actually came up good.....
Removed all un-needed engine bay shit......
Fitted up motor and W58 gearbox....
you still need a turbo manifold?
can do a deal with some street springs if youre keen?
Just a few more pics of progress.....
Engine is done now has all the turbo gear installed, (only thing to do is the turbo Water lines, but I need a AE71 heater core first as it's leaking inside the cab.)
Dump pipe fitted,
All new fasteners/bolts etc for turbo setup (replaced all old nuts and bolts with new quality ones)
completly wired up,
Custom fitted Golpher Alluminium AE86 Radiator with twin 10" fans,
Autometer Tacho, boost guage and Microtech hand controller fitted,
Re-located battery to behind passenger seat,
I've bought some SSCUS recliner buckets and modified rails to suit....
STILL TO DO:
Intercooler piping,
Fit sandwich plate and oil cooler,
Fit coilovers and front brakes,
Fit R32 brake Master and modify lines to suit,
Make up fuel system, (modify and fit intank VL lift pump,
Fit up Bosch 910 main pump and undercar surgetank,
Fit seats,
Fluids,
Change rear yoke on tailshaft and fit to car
Ok, so done a bit more on this in the last few days.......
Oil cooler setup all done.....
Fuel system is done now.
Consists of - modified tank drain plug into a bottom feed outlet, Pierburg Extenal lift pump, surge tank, Bosch 910 main pump. I had to mount it in the back of the wagon, but it is off to the side and I am gonna make up a cover for it.....
Car is 100% wired up....
Front brakes and coilovers are in. R32 master cyl fitted with modified lines..... I have ended up using the G'Reddy coilovers anyway, As I dont want to pull the blue 86 apart anymore to rape parts off it....
BEFORE:
AFTER: Greddy Coilovers, Hoppers stoppers Brake kit (XR8)
Good progress with this,How come you couldn't keep the fuel setup underneath?
Couldn't find a spot I liked.....
Cant put it above diff, Cant put it near wheels, cant put it near outside panels....... Nothing safe in my opinion....
