Results 1 to 10 of 15
Thread: Manabu Orido - GT86 Lexus IS-F V8 Powered Drifter
    Noooob
    Default Manabu Orido - GT86 Lexus IS-F V8 Powered Drifter
    As the 2L boxer engine lacked a bit of poke, Manabu Orido took it upon himself to increase the power by dropping in a v8 Lexus IS-F engine into his Toyota 86.
    Here is a video of him "testing" the new found power.
    Senior Member AIROCOBRA's Avatar
    Bob
    ACT
    Weston
    Matt that is ....... There are no words . Where do I SIGN , what or who do I need to SELL , who do I need to sleep with ( or not sleep with ) to make this happen. Now this version of the 86 I would buy.
    Love the way he can only use part throttle most of the time as it seems to have so much mambo , and when he does give it a bit , smoke city .
    Would love to know the actual specs of the donk and drive-train ?
    ONLY THE GOOD DIE YOUNG ------ I MUST BE VERY VERY VERY BAD
    AE86 4AGE 16V N/A TRACK CAR ( RED )
    AE86 ROLLING SHELL --- IN CASE i F-CK UP !!!!!! (PRIMER )
    AE86 ADM UNDER CONSTRUCTION ( STREET CAR) 4AGE 16V , (RED )
    AE86 Trueno ( RESTORE TO PERIOD GOODNESS ) White
    AE86 4AGZE Wreck ( to be rebuilt into Khannacross fun car )
    KE 15 x 2 -- SPRINTER ( RESTORE TO PERIOD GOODNESS ) RED
    TE72 (T18) X 2 BIT OF PAINT , BIT OF MECHANICAL way we go RED
    Soarer 1995 1JZ Factory 5speed (R154 )
    Noooob
    Lol yeah it is pretty insane...
    Noooob
    Noooob
    Noooob
    We've all done these shots during a build..
    Motec Ecu to keep the engine under control
    Nice shot of the office.
    Now thats a driveshaft..
    The Lexus Engine has found its new home.
    Another shot of the office.
    Now where do i get me a set of these
    But the engine specs for a stock 2UR-GSE is 4969cc , dual vvti / vte-ie on the intake cam
    89.5mm stroke with a 94mm bore
    311KW at the fly at 6600rpm
    505nm 373 ft lbf of torque at 5200rpm
    And also D4-S direct port injection.
    This being modified I would expect it to have a few more ponies than stock.
    From memory the engine is stock other than cams/exhaust and ecu .. Those videos are quite old
    Jake
    Northgate
    Should do something with the throttle to make it so its not getting opened and closed so ofter, with the v8 should just be able to ease it on and off and keep it going.
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    so unnecessary, yet so necessary
    Noooob
    Build pics are now up...
  1. The battery powered GT86
    Last Post: 28th November 2012, 09:59 AM
  2. lexus v8 in ae86...
    By Jamie in forum General Topics (No Technical Questions)
    Last Post: 28th April 2008, 01:35 PM
  3. v8 lexus into ke70?
    By j_casey87 in forum Technical - Questions
    Last Post: 20th February 2008, 05:42 PM
  4. TT lexus v8
    By GzePwr in forum Toyotas in the Media
    Last Post: 8th February 2007, 09:02 PM
