$800 want em gone!
SOOOLD
hey guys i have my mikuni setup off my 86 for sale as the engine is now going injected and have no need for these anymore
they have recently had a freshen up and run nicely
they were off my worked smart port 4age runing a big port head, 292 hks cams, forgies etc
was a good setup for what i had, started first go easy, idled nice and held 10,500rpm quite good and also i ran a stock jdm 86 ecu for ignition
so if your looking for old school, and have a worked 4a these will do the trick!
carbies come with:
manifold to suit big port
trumpets
fuel reg
fuel guage
linkages
custom neat wiring loom to suit jdm big port ecu
and injector hole milled to size plugs to replace injectors
pics:
these will bolt on and start
all u need is a carter black fuel pump and your ready to go!
price: is SOOOLL
will post at buyers expense
mobile: 0419 859 630
cheers
adam =)
$800 want em gone!
You HAVE A pm
ONLY THE GOOD DIE YOUNG ------ I MUST BE VERY VERY VERY BAD
AE86 4AGE 16V N/A TRACK CAR ( RED )
AE86 ROLLING SHELL --- IN CASE i F-CK UP !!!!!! (PRIMER )
AE86 ADM UNDER CONSTRUCTION ( STREET CAR) 4AGE 16V , (RED )
AE86 Trueno ( RESTORE TO PERIOD GOODNESS ) White
AE86 4AGZE Wreck ( to be rebuilt into Khannacross fun car )
KE 15 x 2 -- SPRINTER ( RESTORE TO PERIOD GOODNESS ) RED
TE72 (T18) X 2 BIT OF PAINT , BIT OF MECHANICAL way we go RED
Soarer 1995 1JZ Factory 5speed (R154 )
Bump! Need to fund 3s!
bump
Price drop! 700!
Bump
Forgot about these
Still for sale!
Bump!
$600 need these gone
Would you take 500 minus the manifold/throttle lever and wiring? I'm looking to put it in an 18rg
