Results 11 to 20 of 25
Thread: Ae71 4age conversion
  1. #11
    Jun 2009
    Imran
    St Clair
    Ok so it's a ke70 , I think 3k with 4 speed manual , will a t50 bolt onto the tailshaft ?
  2. #12
    Nope you'll need an ae71 tail shaft....
    Mounts from Jord0 to suit the ke70 x-member and an ae71 pedal box / modded ke70 one.
  3. #13
    Jun 2009
    Imran
    St Clair
    So an ae71 tailshaft will bolt onto the diff Aswell ? Could I use a sprinter pedal box ? And will I need to use a sprinter x member for the 4age ?
  4. #14
    Veteran anastasios's Avatar
    Taz
    Earlwood
    Your KE70 should have a 4k not a 3k, which is a 1.3l
  5. #15
    Jun 2009
    Imran
    St Clair
    I'm not exactly sure what it is
  6. #16
    Ae86 peddle box won't line up without modification.....
    So your list of parts are
    * 4age
    * RWD manifold (if smallport you can get a t3 adapter)
    * Ae71 peddle box or jordo's modified ke70 exchange one
    * Jordos ke70 to 4age mounts + t50 xmember Link here to his products:
    or
    - Ae71 X member
    - Ae71 Mounts
    - Ae71 Gearbox X Member
    * Hydraulic Clutch Master / Slave Cyclinder / Line
    * Optional JDM Bell housing
    - Makes life easier as heat is away from the clutch slave
    * RWD 4age extractors
    You pretty much can buy most if not all bits you are after from the suppliers on here....
  7. #17
    Elite rthy's Avatar
    Leo
    Tulla
    why not 5k or 7k convo?
  8. #18
    Jun 2009
    Imran
    St Clair
    Matt if it's ok could you pm me your number so I can call , would make life alot easier
  9. #19
    Senior Member J0RD0's Avatar
    Feb 2010
    Jordan
    so you bought the pedal box off me, will you be needing a mounting kit to go with?
    THE EVOROLLA none of this SR shit . . . EVO 7 powered bitches
    https://www.facebook.com/KeConversions
    KE conversions - making your conversion simple
    4AGE CA18 SR20 BEAMS 1UZ to KEXX mounting kits and hydraulic pedal box's available
  10. #20
    Jun 2009
    Imran
    St Clair
    Mounting kit for what
  1. 4age bigport 16v conversion for KE70/AE71
    By leigh4110 in forum Car Parts For Sale
    Last Post: 6th July 2010, 06:53 PM
  2. FS: 100kw 4age engine conversion in ae71
    By marlon in forum Cars for Sale (Toyota Only)
    Last Post: 31st March 2009, 08:42 PM
  3. WTB: AE71 Manual conversion parts + 4AGE
    By thesim in forum Cars or Parts Wanted
    Last Post: 15th January 2009, 07:45 PM
  4. Putting a 4age into my ae71 + manual conversion
    By Ashley86 in forum Technical - Questions
    Last Post: 12th February 2008, 05:46 PM
