Page 3 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 21 to 30 of 83
Thread: Inverted Panda Project.
  1. #21
    May 2010
    Tyrone
    So a little has happened since last update:
    Paid for the coilovers, just gotta pick them up.
    Ordered 2 bride gias replicas
    Bought Braided brake lines
    Spoke to AJPS and ordered a heap of stuff:
    Adjustable panhard rod
    Adjustable tie rod ends
    Cusco engine and gearbox mounts
    Trailing arm bushes
    Front and back swaybar link and D bushes
    Dash mat
    T-50 shifter kit
    And a front end kit which includes:
    Super pro LCA bushes (in ajps specified 93a duro)
    Super pro caster rod bushes
    Super pro/AJPS rack mount bushes
    Lock spacer
    Slim line Ball joints
    Rack ends
    Slim line tie rod ends
    Rack boots
    Also bought almost all the same stuff for the track hack :p
    Last thing, the pallet from Justjdm should hopefully arrive tomorrow so will update again when it gets here.
  2. #22
    Oct 2011
    Tore Daniel
    Norway
    Norway
    Norway
    This will be a high-spec trackbanger when finished! Cant wait for the end result
    Also, not to jack your thread, but I have a question or two:
    I see you have the same motorlift as me (Capable of 2000kg), I was just wondering if it lifts high enough to get a 4A motor (Without tranny) clear of the car without any banging around or tricks needed? My 86 currently has no engine head on the block, so I use the head bolts for lifting it out (And should provide with more leverage), so I was just wondering if there is much space to play with here
    The lift also sits lower on the ground than the car because of extremely uneven concrete floor in the shed/building, so I`ll put some planks under the rear wheels of the lift to hopefully level out the height differences a little.
  3. #23
    Will do it easy...
  4. #24
    Senior Member mcBen's Avatar
    Mar 2012
    Eastern burbs
    farkin hell this is coming along so quick, keen as a lima bean for post-paint pics
  5. #25
    May 2010
    Tyrone
    Slide the bar out to 250kg and you could probably lift the engine over the roof.
    I wouldn't stress about the back wheels at all since they lift off the ground when lifting normally anyway. Only the front 4 need to be stable. Also I'd make it so you can move the car once the engine is up cause these aren't the easiest to move around with an engine hanging off 'em :p
    Oh and this ones my daily
    Your not the only one haha. Fck I hope it turns out ok, 'cause if it doesn't... :banghead:
    Oh and I received some sex today
  6. #26
    Aug 2010
    Geoff
    mt dandenong
    good build thread so far, dont normally see them happening this fast.
    spoken to vu at dt to see how its going? i might have to do a drop by and get a sneak peek
  7. #27
    May 2010
    Tyrone
    Haha yeah, but the speed comes at a cost...
    I dropped in to see Vu recently, payed for half of my job up front (didn't have to but better in his hands then mine.. trust me)
    He won't start work on mine till start of new year which is fine cause my pallet of stuff hasn't arrived from justjdm yet which has the front clip on it that Vu needs.
  8. #28
    May 2010
    Tyrone
    So just got off the phone to toll.
    My pallet from justjdm will be delivered on Monday
    Yay! (dances)
    I'll start cleaning up the engine soon, so look forward to that
  9. #29
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    impressed.......
  10. #30
    May 2010
    Tyrone
    Thanks
    But I won't be bringing this one to Raleigh haha :p
  1. Blacktop 20valve panda sprinter unfinished project
    By AEA-386 in forum Cars for Sale (Toyota Only)
    Last Post: 11th October 2010, 09:42 PM
  2. project panda drift slut
    By 1sik20valve in forum AE86 Owners Forums
    Last Post: 2nd December 2009, 10:23 AM
  3. My Panda
    By dodgybrooks in forum AE86 Owners Forums
    Last Post: 14th August 2007, 03:44 AM
  4. To panda or not to panda
    By 20v Monster in forum Offtopic Discussions
    Last Post: 8th October 2006, 03:02 PM
