Page 8 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 71 to 80 of 83
Thread: Inverted Panda Project.
  1. #71
    May 2010
    Tyrone
    Engine is in, running well.
    Just wanna relocate the fuel filter to neaten up the bay a bit more.
    Unfortunately an exhaust stud snapped so gonna have to buy a stud remover an take it out before it's driveable again. Hopefully will have the exhaust sorted by the end of the week then I can book it in for a wheel alignment and move onto the interior
    Sent from my SM-G935F using Tapatalk
  2. #72
    May 2010
    Tyrone
    Managed remove the broken stud and swap out the exhaust during the week so engine itself is pretty much sorted.
    Need to make up a bracket to mount the overflow bottle but have installed it temporarily so I can drive the car.
    Only a few things left remaining to be done in the engine bay now, need to install a thermo fan switch, install a washer bottle and relocate the fuel filter but other than that I'm pretty happy.
    Need to bleed the brakes and have it booked in for a wheel alignment on Monday but haven't managed to make a start on the interior yet.
    Hopefully will make some more progress in the next week or so!
  3. #73
    Member Fooly Cooly's Avatar
    Ed
    Gold Coast
    very nice mate!!! keep the updates coming
    she looks great!
  4. #74
    May 2010
    Tyrone
    So, has been a month since last update, unfortunately haven't had as much time to make progress as I would've liked due to uni, work an family commitments but I've done what I can here and there.
    I've relocated the fuel filter for a neater finish whilst still leaving it easily accessible.
    I swaped the bleed valve and clutch line on the slave cyl because the line was touching the exhaust which has alleviated the issue.
    Also filled in the hole in the front bar for a less noticable finish.
    Finally, I've removed the diff centre because it was whining even though it seemed to operate just fine. Looks as tho the crown an pinion is worn so I'll be enquiring into how much it'll cost to replace them an go from there.
  5. #75
    May 2010
    Tyrone
    Another Month has passed an still not finished. Hoping to have this more or less completed by xmas but we'll see how my luck runs!
    Replaced the crown and pinion gears in the diff and she's now blissfully quiet compared to before!
    Re-Sealed the windscreen because it was leaking and even managed to get the top weatherstrip to sit relatively nicely!
    Interior is almost complete, will be removing the dash and Flocking it in the nect coupla days. Only a few bits and pieces left to prep and paint now!
    Unfortunately Ive had issues with the bonnet and that'll need resprayed when the car goes back to the paint shop for final touchups but all in all she's almost there
  6. #76
    Junior Member Dorifutokingu's Avatar
    Sep 2017
    Arath
    TX
    Houston
    United States
    Such a beautiful, careful build. Amazing progress!
  7. #77
    May 2010
    Tyrone
    Finally managed to get around to flocking the dash! Unfortunately I forgot to take a before pic for reference Hopefully It still looks good once it's set an the excess has been blown off
    Still, pretty stoked with the finish so far!
  8. #78
    May 2010
    Tyrone
    Dash is back in and sorted, just have to remove an paint the rear plastics now and the interior will be more or less complete
    Having some trouble with cyl 2 losing spark, not sure if its wiring or a faulty coil. It's intermittent so will have to do some testing an pray its not a difficult fix lol
  9. #79
    May 2010
    Tyrone
    So, finally got a chance to work on this again a bit today. Accidentally left the ignition on an the battery went flat so that along with xmas etc. has kept me busy.
    I swapped the coils around and am still having intermittent issues with cyl two so wiring is the cause. Pulled back the covering to see if there was anything obvious but to no avail so will have to troubleshoot further with a multimeter.
    She's getting pretty close to being ready for sale now, will be organizing a visit to an auto elec soon to sort the wiring for the washer bottle, rear demisters and get the taco working as well as some other bits n pieces.
    Still need to paint rear plastics an go back to the paint shop to repair some small damage and finishing touches.
    Hoping by the end of the month it'll be ready to advertise!
  10. #80
    Veteran ae8zn6's Avatar
    Robbo
    Gippsland
    I have been considering flocking my dash too. Black interior probably makes a difference to the overall look once flocked.
    Do you mind telling us roughly what it cost? I assume you needed to fill cracks first too?
    Current Cars:
  1. Blacktop 20valve panda sprinter unfinished project
    By AEA-386 in forum Cars for Sale (Toyota Only)
    Last Post: 11th October 2010, 09:42 PM
  2. project panda drift slut
    By 1sik20valve in forum AE86 Owners Forums
    Last Post: 2nd December 2009, 10:23 AM
  3. My Panda
    By dodgybrooks in forum AE86 Owners Forums
    Last Post: 14th August 2007, 03:44 AM
  4. To panda or not to panda
    By 20v Monster in forum Offtopic Discussions
    Last Post: 8th October 2006, 03:02 PM
