Results 1 to 10 of 12
Thread: 20v Silvertop vs Blacktop - What are the differences
    Default 20v Silvertop vs Blacktop - What are the differences
    Internal Differences
    * Rods
    * Pistons
    * Head
    * Chamber size / volume
    * Inlet ports
    * Oil pump
    * Hydraulic Tensioner
    * Timing belt
    * Cam Gear Degrees
    * Cams
    * Blacktop is interference
    * Flywheel - Blacktop has been lightened significantly. cut outs around the bolt holes.
    External Differences
    * Quad size
    * Colour of cam covers
    * AFM vs MAP
    * ECU
    * Wiring Loom
    * Airbox
    * Ignitor bracket - silvertop has starter relay mounted on it.
    Exact Same Parts
    * Rings 1.2mm top 1.5 2nd and 3mm oil ring
    * Dizzy
    * Coil
    * Ignitor
    * Block
    * Crank
    * Head bolts
    * Injectors
    Parts that can be shared
    * Silvertop timing setup IF you use the silvertop oil pump
    * Rods
    * rings / bearings
    * Cam covers
    Pics will come and i'll update it properly with CR ratios and that , but for now it is a placeholder...
    Sep 2011
    Roy
    Northern Melbs
    New Zealand
    injectors are also different, blacktops having the superior spraying pattern.
    Who told you that???
    The part numbers are exactly the same
    23209-19015
    Steve
    I agree Matt, i have had both in my hands and they are indeed identical on the outside.
    If there was a difference it may of been right at the very end of the bt run or the very early st engines, but i am yet to see any part numbers to support this.
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    rings and bearings can be used in both 1.2mm top 1.5 2nd and 3mm oil ring same as each other bearings are exactly the same aswell
    the dyno pull to 300rwkw
    Sep 2011
    Roy
    Northern Melbs
    New Zealand
    I was told it by a guy who has raced an ae101 for years.
    Aware the fitment/ flow rate / part numbers etc are the same, nevertheless, he thought the spray pattern between them was different.
    Though allot of people use 1jz injectors...
    Mathew
    Sutho Shire
    1j 2j 3sgte use all the same fitting injectors as the 20v spray pattern between black and silver is the same
    waiting to confirm that the crank pulley on the blacktop is 2mm thinner, and the timing belt drive is 2mm wider
  1. WTB: 4AGE 20V Silvertop or Blacktop around the 21st of March..
    By s3phro in forum Cars or Parts Wanted
    Last Post: 4th March 2011, 08:44 AM
  2. Blacktop 20v ECU on silvertop engine
    By 99Westy in forum Technical - Questions
    Last Post: 31st August 2009, 02:11 AM
  3. 4age 20v Blacktop vs Silvertop
    By shelldrake in forum Technical - Questions
    Last Post: 4th June 2008, 02:09 PM
  4. 20v: Silvertop or Blacktop???
    By HYPNTK in forum Technical - Questions
    Last Post: 3rd November 2006, 05:45 PM
  5. silvertop 20v or blacktop 20v
    By Cj_sullivan in forum General Topics (No Technical Questions)
    Last Post: 6th September 2006, 12:42 PM
