Got a lil bit of work done, new catch can, hydro clutch sorted, new inlet n exhaust gaskets fitted, alt mounted, started the wiring, coil mounted. Getting closer. also fucked with the interior a bit.
cheers thanks... ill try and have a look at some headers in 86s for size..
Cool rig!
I like the woodgrain wheel better. Progress?
Yeah fair bit of progress, finished the wiring, put a new clutch fork in, got it turning over, fuel system done. Still a lot of work to do, need to build diff, sort rear suspension, exhaust and mount radiator and thermo*s
The Woodgrain will be going back in and a different shifter
just bought this to go where the clock was, and have matching oil pressure, oil temp and water temp omori gauges to go either on the glovebox lid or where the stereo is.
Bit of progress, after setting the timing, putting in some brand new plugs and fresh fuel it started up first pop. Pretty stoked.
Have dropped my leafs off to get lowered 3"s, reset and some solid steel blocks made up to slam the fuck outta it.
Also fitted the tacho where the stock clock was, snug fit. Omori water temp gauge on the way.
Fitted AE86 TRD 2 Way Lsd to the 1200 housing, bought a badass lathe and machined up an adaptor to bolt it to my tailshaft.
Im off working away for a couple of weeks, when i get back the remaining eBay shit will have arrived, springs will be done and ill be able to backstreet it to the exhaust shop n skid it home Yeah Roy!!
3 year build coming to an end!
What did you use for peddle box?
Stock pedal box but have a Maddat hydro clutch kit with brand new slave and beefed up clutch pedal.
New exhaust done
Still gotta get some custom blocks made for more lows, gonna get a custom tail shaft built as there is a bit of a vibration there that im not happy with and getting a custom mechanical 2ndaries dizzy built.
Thinking about selling it so if you're keen shoot us an offer.
Selling?? BS! How much you after?
Woh no updates for a year, will drag it out of the garage soon and do a skid.
This is what made me wanna do a GE ute! Keen for an update!![]()
