From google... but may not be relevant...
Hi guys,
I finally started my f20 in my sprinter but have an issue with the clutch not engaging.
The pedal feels fine and I have adjusted it to get as much clutch fork movement as possibly so now think I know what the issue is. The engine was decreased and steam cleaned with the clutch assembly fitted and I'm fairly confident the clutch plate has seized onto the flywheel. Does anyone have a suggestion as to how to get it off without removing the box?
It worked!!! Thanks matt
Awesome....
Don't be surprised if it takes a bit for the clutch to bed back in.
4th gear, slip clutch few seconds, then turn off and leave to cool
exedy "resurface" procedure
