13" ssr mk3's, pair or set?
ELECTRICAL
Brand new Top Gun 4k spark plug leads - $25
Repco 4k spark plug leads, worked fine when car was running - $5
KE70 Bosch alternator, worked fine when car was running - $25 SOLD
Near new Bosch SU 12R ignition coil, used for not even 500kms. - $35
Bosch GT40R ignition coil, not sure on condition, but was running ok when my car was running - $20 SOLD
RACV Battery, about 6 months old. out of charge but is like new - $50
MOTOR/GEARBOX
5 speed K50 manual conversion, comes with EVERYTHING! starter, tailshaft, pedal box, clutch cable set up etc. comes with a brand new exedy clutch kit aswell (will not seperate) - $450 SOLD
Ported 4k head (rocker cover included with new gasket and pcv valve) with heavy duty valve springs. head gasket and thermostat + thermostat housing included (found out theres a bit of a dent on the face, not sure if it will come it with a resurface + thicker head gasket) $100 SOLD
k motor extractors, good condition - $150
k motor twin carb manifold (webers/dellortos), had another fitting drilled and tapped in opposite runner - $200
Bare, stock 4k head. not sure if warped. (still has valve springs and valves) - $20
Reconditioned KE70 radiator, used for about 500kms. comes with near new hoses and shroud - $100 SOLD
Stock 4K carby with intake + air cleaner (ran fine when car was running, low k's) + manifolds. $30 CARBY SOLD
KE70 full exhaust, first half a bit rusty, second half and muffler no rust, only a couple thousand k's old - $40 SOLD
ARP 4k head studs and nuts - $80 SOLD
PANELS
Flat front panels in primer, no rust. comes with everything. beaver panel, scuttle panel, lights, indicators, grill, bumper etc. - $350 SOLD
All doors for sale aswell, no rust and all straight. the passenger door had rust (bogged) all glass perfect, door cards not included - $40 each SOLD
WHEELS
PAIR 13x6.5? 4x114.3 GENUINE SSR MK.3's, nothing sepcial, bit of rash. $250
PAIR 14x7? 4x114.3 Centreline copies, very good condition. $250
4 full tread 13/165 tyres. 2 bob jane, 2 some other brand - $120
SUSPENSION
Standard rear shocks - $30
Standard rear springs, uncut - $20
Brand new Gabriel Ultra VN wagon short stroke shocks - $80
near new rear lenses & globes, about 3-4 months old. - $25 each RIGHT TAILLIGHT SOLD
tacho dash, cracked glass - $60
clock dash, low k's - $20
SSL ford au king springs, uncut. $80 SOLD
4k hi cam plastic fan and pulley, fan has 2 broken bolts. - $10 SOLD
near new 4k hi cam water pump, still brand new inside, comes with bypass hose and bolts. no gasket - $40
4k fan belt, looks good. - $5
Speco mechanical fuel pressure regulator 1-6psi, has hose fittings but not sure what size. used a handful of times - $50
4k mehcanical dizzy - $20
ke70 brake booster and master cylinder, no leaks - $60
NEGOTIABLE ON NEARLY ALL ITEMS!
THESE ARE ALL OFF A COMPLETE KE70 THAT I AM PARTING OUT, ASK AND I MIGHT JUST HAVE THE ITEM YOU NEED (I AM NOT PARTING OUT INTERIOR OR DIFF/FRONT SUSPENSION/BRAKES AS OF YET)
located in northern suburbs, pictures up tomorrow
Yeah, they're a pair. Should of specified.
bump!!!!!!!!
extractors and twin carb manifold now for sale
added some more suspensions parts
bump
bump
Still got :
Stock 4K carby with intake + air cleaner (ran fine when car was running, low k's) + manifolds???
Yeah mate, still got it.
