Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 31
Thread: Oil For My gt86
  1. #21
    Holden have had 15k service intervals for close to a decade now. Does the or every 6 months caveat still apply?
  2. #22
    Veteran blake.'s Avatar
    Jun 2009
    Blake
    Penrith
    Vw has 15k/12 month intervals too, they can do this due to the high quality of oil.
    A crafter on the other hand has 30k/12 month intervals as it has the same oil but 9L of it.
    We get cars in which go 20-25k between services and never have had a problem with them.
    So if you intend on leaving your 86 standerd, as in no major mods like turbos, go to Toyota and get the genuine oil for it. Toyota and Subaru would have invested thousands of dollars to manufacture the perfect oil for it. Don't let anybody mislead you and say its shit.
    bursting ovaries since 92'
  3. #23
    Veteran ae8zn6's Avatar
    Robbo
    Gippsland
    Yeah all good, on the other hand my missus my09 liberty gt spec b had a service interval of 12.5k, without my knowledge she was servicing it closer to 15k and it spun a big end bearing before 100,000
    She doesn't drive it hard either.
    So whilst I realise the warranty will still cover me, I would prefer not to damage the motor if there are some skid pan sessions + super sprints and motorkhana in that first 15k.
  4. #24
    Subaru is renowned for spinning bearings if the oil gets low...
  5. #25
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    Easy solution, check your oil every now and then like you should be doing anyway.
  6. #26
    Gone
    Joel
    Picton
    Regardless of the oil that is in the engine, letting it go over 10K is a sin on my books.
    Regular services at 7-8K, even when using a good oil, I can notice an engine becoming noisier and "restricted" via friction as it gets up to 10k old.
    I believe regular doses of clean, fresh oil provide the least expensive maintenance an owner can give an engine.
    In aircraft horizontally opposed engines (boxer) the oil and filter is changed every 50hrs.
  7. #27
    Jake
    Northgate
    I do my landcruiser every 2.5k but oil is free so yeah, haha. Do my old mans camry every 5k.
    Also make sure you ask what oil they're using because I know a dealership that I may or may not work at that only uses 10w30 in everything now that is designed for the VVTI engines not that it will probably matter in the 86 but they get old land cruisers in sometimes and just get told to use that oil, I use oil from hino for the diesel trucks in my cruiser so its good.
  8. #28
    Gone
    Joel
    Picton
    And that's the problem with workshops... They will generally have 44's or whatever filled with eg. A 10w40 and they will use that in every engine, even if The manufacturer specs different.
    For them it's about cost, not what your engine actually needs.
  9. #29
    Jake
    Northgate
    This one has huge tanks 2 of them full, it is good oil and most of the new diesels to specify a very similar grade oil so I suppose its not too bad. You can still always buy the bottles of oil from a Toyota parts department but would probably be at your cost because of the capped price servicing.
  10. #30
    Senior Member gg004's Avatar
    Glenn
    Queensland
    Gold Coast
    not all workshops do that, just the small backyarder type operations would do that. where i work we have to stock a huge range of different oils so we use the correct grade of oil required by whatever vehicle it may be, otherwise it will upset warrantys ect if something were to go wrong and it came back to us putting in the wrong oil or oil grade. you wont upset your factory warranty by having serviced by non dealer mechanics, but they must use the correct grade of oil and folllow the log book service guide. i am suprised about the other comments refering to a toyota dealer throwing the wrong oil in cars, how would they sort out warranty hassles if something went wrong and it came back to them putting in the wrong oil?
  1. Rogue Motorsports Race GT86
    Last Post: 23rd December 2012, 07:58 PM
  2. The battery powered GT86
    Last Post: 28th November 2012, 09:59 AM
  3. Driving a GT86 at the nurburgring
    By AJPS in forum Info / Pics & Discussion
    Last Post: 31st October 2012, 07:05 AM
  4. Convertible GT86 News!
    Last Post: 23rd October 2012, 11:47 PM
  5. Leaked trd cataloge for GT86!!
    By PT86 in forum Info / Pics & Discussion
    Last Post: 21st June 2012, 05:58 PM
