money, a socket set, a jack, and what lawson said
wat do i need to put some coilovers in the front of my ke70.
2 springs of ID 60mm or 65mm. Your choice of spring rate and length.
1 coilover kit, containing threaded tube and lock nuts, diameter to suit your struts.
Cut spring hanger off your struts, weld the threaded tube on.
Choose springs at
Buy threaded kit at revolution racegear or similar.
OR buy a complete coilover setup off a used AE86 from Japan.
But if you have to ask... it's far easier to buy everything off Lawson. But just letting you know some options.
