Results 1 to 10 of 47
Thread: 4age over heating issues
    Jon
    Durack
    Default 4age over heating issues
    Hi all,
    I have no end of drama's with my 4age. For some reason it keeps on over heating only after small drives. It can sit and idle/rev in the garage no dramas for ages but as soon as its driven it over heats quickly.
    I have fixed all leaks the water pump had, brand new alloy radiator 10" thermo fan and it still over heating. Thermosat was replaced about a month ago and has driven 3 times.
    1st time: leaking from bottom of water pump - re gasketed and sealed - fixed
    2nd time: no leaks but top tank of my excel radiator expanded causing leaking. - due to pressure...
    3rd time: new alloy rad, all leaks dealt with little longer drive started idling funny got up to 100deg when i pulled into my garage, opened bonnet and BOOM back hose of the engine comes off coolant everywhere.
    Possible reasons for my issues:
    Radiator cap not releasing pressure - Issue occurred on two different radiators
    thermostat stuffed - It's new but haven't replaced
    System not bleed. - have re-bleed the engine
    Question:
    Can i run the engine without a thermostat, or am i best to replace it?
    You can run without a thermostat, though it would take allot longer to get up to temp + cause it to run cold more so on free way driving. Taking it out is a quick / easy check to do.
    Bleed the system, but you'd have a bouncing idle as soon as any form of temp gets into the car.
    Is the radiator cap common to each radiator?
    If that doesn't work, get your radiator pressure tested + that check they do to detect oil in the coolant.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    have you considered a head gasket leak?
    Jon
    Durack
    Matt - have bleed the system and caps are what came with each radiator. But will take it out and test
    Sam Q - It was brand new before this Jibba Jabba started happening. but it is a thought in the back of my mind!
    West
    Did you test the thermostat before installation?
    However I run a car with no bypass and im sure that before the thermostat opens I have absolutely no problems with pressure build up.
    Is the radiator blocked?
    Is everything hooked up as per the factory when it comes to cooling hoses?
    If everything is as it should be have the compression tested.
    You may have initially had a thermostat failure that has lead to overheating. Then that may have led to a BHG.
    Is the coolant getting foamy from having combustion gasses or oil in it?
    Is there water in the oil?
    Jon
    Durack
    Hi Matt,
    Coolant doesn't appear to have oil or get foam.
    I'm going to rip out the thermostat tonight
    Jon
    Durack
    I bleed the system again and ran it for ages to make sure there wasn't any air in the system. seemed to be going fine. took if for a short drive (500m)and coolant pissing out my bonnet.
    got it home and my over flow bottle is full and is leaking coolant from where the back of the water pump meets the block.
    I'm so feed up with this fucking car, anyone want to buy it? or is there a decent person/workshop i can leave it at until its driveable..
    I'd be getting the head checked.... Who built the engine?
    ryan
    This is going to sounds really silly, but have you checked whether your themo fan is blowing air the right way? might explain why it only gets hot when your take it for drives and not while sitting still.
    Jon
    Durack
    Matt - Timbo and I did it. havent had any dramas until the old pump thorw the clutch fan off.....
    Sprinter freak - Checked and its correct as per the markings on the fan itself.
  1. 4age 20v issues
    By ryebred_06 in forum Technical - Questions
    Last Post: 27th November 2012, 09:11 PM
  2. 4age bigport idle/fuel issues
    By BlueLevin in forum Technical - Questions
    Last Post: 23rd June 2010, 05:39 PM
  3. best coolant? heating issues sr20
    By irl86 in forum Technical - Questions
    Last Post: 14th March 2010, 10:16 AM
  4. sr20det overheating issues (I KNOW ITS NOT A 4AGE)
    By Fozz in forum Technical - Questions
    Last Post: 22nd March 2009, 11:14 PM
  5. 4ac -> 4age gearbox issues
    By yes02t in forum Technical - Questions
    Last Post: 12th August 2008, 11:15 AM
