Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 11 to 20 of 47
Thread: 4age over heating issues
  1. #11
    Veteran timbo's Avatar
    Tim?
    Wild West
    We'll work this shit out. Water parts and motor as a whole were fresh and clean, I'm fairly sure it's going to be thermostat and or the housing. The swap to a new pump back and front housing was the only change before it all went crazy.
  2. #12
    Jon
    Durack
    flushed the whole system out last night and it was flowing freely without the thermostat in. so i think the thermostat is the problem.
    Will attempt to fill it up with coolant today and drive it
  3. #13
    Tim?
    Wild West
    I'm free tomorrow too Jon, so see you next year! Lame, I know...
  4. #14
    did you buy a genuine thermostat? I've lost count the number of times people have bought thermostats only to have it continually over heat...
    Slap in a genuine one and never had a problem again. FWIW - a car shouldn't over heat with water in it. But coolant has the antifreeze properties and a higher boiling point etc...
  5. #15
    West
    I think as long as you put it in a pot on the stove and test it then you can know its working. Id never fit an untested one, genuine or not.
  6. #16
    Jason
    Southern Suburbs
    How are you controlling the thremo fan? Temp switch on inlet to rad or outlet as there are different temp thermo switches depending on position.
    Is the fan on the driver or passenger side of the radiator?
    I have had issues with fan on passenger side but the driver side mounted hoses on AE86 radiators direct most of the water flow on that side, thus the cooled water on pass side cannot keep the temps under control.
  7. #17
    Jon
    Durack
    thermo fan switch is on the outlet and turns on all the time. thermo fan is dead centre of the radiator
  8. #18
    Jun 2011
    james
    oxford
    general area
    England
    If there were no issues before you started work on the cooling system, your problem is almost certainly an air lock.
    Make sure you bleed the system with the heater on its "hot" position
    The heater fan need not be on.
  9. #19
    Jon
    Durack
    Did this and still fills up the over flow bottle......
  10. #20
    Tim?
    Wild West
    Looking at the engine bay from the front, the left heater hose on the firewall should go to the top of the heater tap. Not sure if it would really matter though...
    If you're free tomorrow I'll come over and check everything with you, just call me! Need a driving buddy.
  1. 4age 20v issues
    By ryebred_06 in forum Technical - Questions
    Last Post: 27th November 2012, 09:11 PM
  2. 4age bigport idle/fuel issues
    By BlueLevin in forum Technical - Questions
    Last Post: 23rd June 2010, 05:39 PM
  3. best coolant? heating issues sr20
    By irl86 in forum Technical - Questions
    Last Post: 14th March 2010, 10:16 AM
  4. sr20det overheating issues (I KNOW ITS NOT A 4AGE)
    By Fozz in forum Technical - Questions
    Last Post: 22nd March 2009, 11:14 PM
  5. 4ac -> 4age gearbox issues
    By yes02t in forum Technical - Questions
    Last Post: 12th August 2008, 11:15 AM
