Results 1 to 10 of 15
Thread: Bit of help starting up
    Veteran ae8zn6's Avatar
    Robbo
    Gippsland
    Default Bit of help starting up
    Car - (kind of irrelevant) but Z32
    motor / part in question - S15 SR20DET
    problem - Bastard won't kick
    occurs/started when (if applicable)- see below
    personal situation (if applicable)- Married with 2 dogs!?!
    OK,
    I bought a car with SR in it. Motor ran great...
    Got it home, motor ran great...
    putted it around the driveway a bit, motor ran great...
    pulled off AFM and moved the ecu around a little, motor ran like ass (no doubt just limp mode)...
    Then motor ran the tank out of petrol... Put more fuel in the tank
    Motor won't start.
    I have reconnected the AFM, moved the ECU back to where it was. It has rail pressure, fuel is flowing into the return line. I have spark at the coil and the plug, I haven't changed the timing.
    (fuel, spark, timing)
    I tried spraying accelerant up the inlet and still no go. Cranks fine but absolutely zero kick (at all)...
    Has me stumped, Only thing I can think is clogged injectors, but then the 'start ya bastard' should have worked (at least a little)...
    Not even a splutter....
    ...bit of help?
    thanks guys
    Current Cars:
    Senior Member pt_y2k's Avatar
    Paul
    What kind of pump is in? Ran outta fuel,fucked the pump now got low fuel pressure? Uprated pumps like walbros are a bastard if ya run them dry!
    Robbo
    Gippsland
    Narh, would be running Z32 fuel pump. They are good for around 700hp, so there would have been no need to change it. Also would the fuel pressure reg be sending fuel to the return line if there wasn't enough rail pressure?
    Thanks for the idea though!
    Current Cars:
    Veteran Skylar's Avatar
    Ken
    Unplug the AFM? Motor should start and idle rock solid but it won't wanna rev.
    Is the loom modified to suit Z32 or just a standard loom? The reason I ask is the b/w power wire for the afm and cas could be shorting out when you moved the AFM plug if it was a pretty dodgey install.
    Are the injectors pulsing?
    Does fuel gush out the return or just pour out without any gusto?
    Paul
    Well if you have good spark and fuel at the rail it has to be an injector power/trigger issue or fuel pressure? theres a big difference between 20psi and 40 psi of fuel pressure although both will do the same thing when ya open a hose...
    Ken
    I find it odd that the car won't start with when you spray something at the throttle. If it is a fuel issue the car would have started on the spray and ran perfect for half a second until it ran lean and picked up rpm just before dying like a nitro rc car when you pinch the fuel line to stop the motor.
    My feeling is it that it's not the fuel system not allowing th engine to run. It may still be faulty but it not THE fault.
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    A SR will still run (idle etc) at 20psi fuel pressure....
    I was with Robbo the other day quickly trying to get this thing going.
    The return fuel line had pressure, and the inlet (appeared) to have pressure too..
    Had spark
    Coils had 12v
    Car earths looked fine
    It really was strange.... It didn't even try to fire, not once... Just kept turning over..... It was almost like an immoboliser. I looked under the dash and found some security/old alarm box. couldn't see much under there. Robbo called the previous owner who said it was all disconnected....
    JoJo
    ACT
    Tuggeranong
    Ask your Dad what happened when it ran out of fuel.
    Did it cough and splutter and then stop?
    Or
    Did the engine just suddenly stop? Did it happen to rev a little first and then die, or just die quietly?
    Prob unlikely, but you know the story of how my CAS just died, which produced same symptoms.... Maybe not, but just sayin
    Robbo
    Gippsland
    Ok, few questions to answer... I am only on my phone, so I might do it in a couple of posts to make it easier.
    Ken:
    The engine loom is standard but has been spliced into the Z32 body loom.
    The AFM wiring seems fine and it is physically no where near the CAS (standard z32 intake position in front of the radiator)
    As far as I can tell the injectors are powered and receiving a pulse (they are negatively switched correct?)
    The return line was pretty much pressurised when I disconnected.
    Robbo
    Gippsland
    Pt_y2k:
    I completely agree. My thoughts were, I need fuel, air, spark and timing. There are no restrictions in the inlet, I haven't changed the timing, there is good strong spark at the plug and the rail has fuel, must have clogged the injectors, but then there was still no life with the start ya bastard right into the throttle body.
  1. starting the car
    By 15LIDE in forum Technical - Questions
    Last Post: 20th October 2011, 11:29 AM
  2. Car not starting
    By dehney in forum Technical - Questions
    Last Post: 22nd February 2011, 03:20 PM
  3. 4ac not starting...
    By squish_m8 in forum Technical - Questions
    Last Post: 18th July 2010, 10:47 PM
  4. starting issues...
    By dori_86 in forum Technical - Questions
    Last Post: 14th November 2009, 12:40 PM
  5. problem starting
    By noobae86 in forum Technical - Questions
    Last Post: 14th February 2007, 08:49 PM
